10R60 Transmission
New York
2022 Ford Explorer, ST
Folks I always check oil and fluids in all my engines and Trannies after about a month of buying the vehicle. Checked engine oil yesterday and I was 1 quart low, my fault and stupidity for not checking sooner I just assumed.
I don’t want to assume the same for my transmission and after doing some investigating I see that our Trannies in the ST is the 10R60. I need to get under and check the tranny dipstick for fluid level. What a stupid ass place for Ford to place it. I read that too. Many people were over filling Trannies, which forces the fluid up into the planetary gears and causes aeration which is a no-no. But then again that’s been true since the first day the tranny was invented. Therefore Ford needs to stop treating us like a bunch of idiots and make things 10 times more difficult to do.
Which leads me to the question the dipstick is numbered from one to five, what is the fluid level range for the 10R60 transmission? Thanks much.
Philadelphia, PA, USA
Adam from ZFG noticed my tranny was skipping 2nd gear. Emailed me to check the Tran fluid. I have 15k miles on it. On the stick it sat on number 6 and should be between 3 and 4.5 for 10R60. That’s what I’ve found after some digging. I’m thinking I’m about 1-1.5 quarts low. Will be taking to shop to top off then continue datalogs.
Greywolf
New York
Thank you that’s all I’ve been able to find out on the Internet that it needs to be between 3.5 and 4.5.
in the many years that I’ve dealt with engines and transmissions , I know for a fact that too much fluid is just as bad as not enough fluid in a tranny.
l1tech
AZ
21 ST
On the dipstick for the ST the level should be between 3 and 4.5 WITH THE FLUID AT 206°-215°F. THE TEMP OF THE FLUID IS CRITICAL. If the fluid is too cold then the level will be low on the dipstick and vice versa.
Greywolf
New York
So for the dumb question, how will I know if it’s between 206° and 215°. would a 15 minute drive in normal traffic. Headed to within that range? Also, should the engine be running when checking?
Ontario, Canada
I believe there is a transmission temperature in one of the menu displays. Otherwise, drive it normally for a trip and then check the fluid.
Greywolf
New York
Thank you for all the answers. I finally was able to find a YouTube video.
l1tech
AZ
21 ST
Good video. Depending on outside temps a 15 minute drive should be enough to bring the trans to temp but being that fluid temp is critical to proper fluid level I'd want to make sure. There is no trans temp in any of the gauges but I'm wondering if there is one in the hidden menu of the instrument cluster. A scan tool that has the capability to read the trans temp would be your best bet.
Ontario, Canada
And boy is my dash dusty.
l1tech
AZ
21 ST
Check out Tow / Haul mode.
What temperature is the C and what temperature is the H?
Ontario, Canada
Point made. You could drive your vehicle, switch to tow/haul mode and determine the normal operating temp range for your vehicle a few times and then use that knowledge to determine if your vehicle is in the range before checking the fluid. The harder part will be access to the hoist as recommended in the video. I think I would use four ramps, but hey nit pic to your hearts content. Geeesh.
FORZDA3
Gloucester, VA, USA
I monitor the trans temp, among other things, via OBD app every time I drive the ExpST and in the inst panel on the Raptor. The ExpST has never been above 200Fand the Raptor ~190F. They both run ~180F during normal driving, so the spec is set to maximum anticipated temp at full hot.
Greywolf
New York
Thread Starter #14
I was thinking on doing the same thing I haven’t tried yet. I have a Phone app called Auto Doctor, which is actually on my laptop also and
connect to a wireless ODB connector. All my other cars tells me that tranny temp among many other useful data points. I never thought about using it on the explorer.
2020 Whitehaven st, Washington DC 20007
If you were to just do a fluid change on the trans, could you safely do that cold? I mean, cold trans, drain the fluid and then fill to the fill line as the service manual specifies
I doubt it. If filled cold once it comes up to temp it would be overfilled then. You could under fill it, bring up to temp then top it off.
I understand. I guess I’m just worried about burning myself under there. I better just man up I guess
At least you can check the fluid, anyone that had an Edge or Taurus knows the levels of Fords stupidity with "lifetime" fluids in transfer cases..... Yeah I put a couple of those drain plugs in over the years.....
Columbus, MT, USA
What a great Video. Answered most questions I had in regards to the tranny. Mine didn't want to shift out of 6th on a WOT freeway ramp entry pull yesterday going to redline and I finally had to let off. Freaked me out. Also the shifts in sport mode are terrible but I wasn't too concerned since that's been a known issue. Not sure if it's too full, too low, or other issues. So first thing I need to do is get under there and check level. At 14K right now. How in the hell do you fill with fluid..........must have to use a squeeze bottle and hose??
