new 2023 ST Explorer and forscan and gauges
Nightshade
Firefighter
Alberta, Canada
Adding to my previous comments--if there is any FORScan changes you guys are curious about needing, shoot me a PM!
20 Platinum
Are there any other changes that can be done to begin with outside of what's already been posted here?
Not sure how limited the PLC is for the Explorer's
Nightshade
Firefighter
Alberta, Canada
Shoot me a PM of what has been found and we can go from there!
SIDE NOTE -- I have unlocked a new FORScan change and made a thread about it. For those interested, take a look!
-> https://www.explorerst.org/threads/drl-led-bar-brightness-boosted-using-forscan.7256/
Vancouver Washington
2020 Explorer ST 401a High Performance
Hi all, thanks for all the work on the spreadsheet. This may be something of a newb question but when I open the software I dont have an IPC tab listed? Is this a file issue or setting I need to dig into? I saw in the IPC part of the sheet that there were the bits to enable gauges like Mustang/F150/Raptor but I dont see a way to load the 720 line items? Thanks in advance.
powerboatr
powerboatr
Thread Starter #26
Ipc 720
Is in forscan and the car
If that's what your saying is missing?
#27
I meant that when I looked for modules while connected I couldnt find the IPC listed for some reason. I am not sure if I need to load an addition al configuration file to have access to it? I am used to Opensource programming in Japanese cars where its common to have to add or patch software so I was wondering if this was a similar thing in order to find the IPC list.
thanks
powerboatr
powerboatr
Thread Starter #28
thanks
Exit programming, relaunch, allow forscsn to download everything before selecting programming
Then give it time to download all the modulrs
sometimes it looks done but its still querying the modules.
Try under asbuilt dialog box
When you select programming
And is your free license or paid license up to date
#29
Thank you for the tech tips. License is paid and fresh, I will connect to it and let it go thru everything like you outlined and report back.
Nightshade
Firefighter
Alberta, Canada
#30
Also to be sure to update your FORScan software on FORScan's website. They have updated the FORScan public version to a newer one recently.
#31
Just got back to this over the holiday and still no luck getting the IPC to show up. I am wondering if it is related to the cable I have, or maybe that was incorrect conclusions when I was reading other people's issues. I have both the Forscan labeled one and a Tactrix J2534 cable. Is there one that is known better than the rest? thanks.
Nightshade
Firefighter
Alberta, Canada
#32
Hey John!
I believe it may be the cable, and thanks for the cable you said you have! I highly recommend the popular OBDLink EX, which is 100% better for FORScan. A lot faster; it's tried and true!
If you are in US: OBDLink EX - Amazon US
If you are in Canada: OBDLink EX - Amazon Canada
Lil Red One
Ogden, Utah
Thanks Nightgshade and Powerboatr for all the work you are doing and posting for forscan updates. Much appreciated. Looking forward to trying them on my 25 when it gets here in early Aug.
Nightshade
Firefighter
Alberta, Canada
#34
Youre very welcome! Glad to hear! I also have a 25 ST incoming as well and will get started on that one as well as soon as it arrives in!
Ambler, Pa
powerboatr
powerboatr
Thread Starter #36
How do you find performance details screen in mine? Does it have to be coded or is it a screen to select??
Sadly you cant..
It's in the system, but our IPC is missing the coding to display it.
You can run forscan in data log screen and select every thing to watch
But driving with a laptop in the passenger seat is a bit unwise
Common sense would say..Ford built an st model.. put it in there at least in sport mode.
#37
Sadly you cant..
Quick bump for a question that it looks you may have answered for Family Guy, I presume the reason I cant see things like the AFR Gauge, Trans temp, oil pressure and such is because the dash itself doesnt have programming for that? Thank you.
Quick edit- finally got around to getting the correct cable to see all the modules. I made the changes in 720-06-01 of the IPC as built.
powerboatr
powerboatr
Thread Starter #38
correct the IPC module is not programmed to see that data that is THERE in the data stream
i am still pestering ford to update it
but they seem to be focused on the new explorer and not the 24s or previous
i have been busy with my 24 f250 so i have neglected to be here much
i have had my 250 since jan 14 and in my actual possession 13 days total as of today
it had rodent damage from dealers lot and then week later transmission tooooook a shiiiiit
Nightshade
Firefighter
Alberta, Canada
#39
Adding to @powerboatr stated, he's correct. Ford is more concentrated on the new softwares and all for 2025+ than they are for the 2024 and below years.
I still have checked in with Ford if there is any updates coming for the 2024 and below, they stated nothing in stream so far. Pretty much stating 2024 and below is "obsolete" due to the Sync 3 as well.
Webb City, Missouri
2022 Ford Explorer King Ranch
#40
You can display gages on your cell phone using Forscan Lite for Android (Don't know about iPhone). You have to have a wireless OBD2 port plug (uses Bluetooth). I run 8 different gages on mine - oil temp, oil pressure, coolant temp, boost pressure, gear, fuel pressure, grill shutters position, and torque. It works great for me.
