Driver seat not reclining 2020 explorer
Ryan599
2020 Ford Exlorer limited
I have the 2020 Explorer limited. My driver seat will lean forward all the way, and lean back until it hits about the 90 degree point then it stops and wont go any further. Ford said it needs a new seat motor which is only sold with the track and would cost $1300 for parts and labor to replace. Its not a fuse problem. Wondering if I need to replace the switch that the seat controls are attached to? I dont buy that the motor is bad considering it moves fine between 90 degrees and fully forward. Anyone have any ideas?
Have you had the Driver's Seat Module firmware updated? There was a module update issued 2-3 years ago for it.
Welcome to the forum.
R
Ryan599
How would I go about doing that?
Are you the original owner or know if any modules were updated? Your dealer can do it but not saying it's necessarily a fix. I would also try removing the negative terminal of the battery for a few minutes. That will reboot all systems. I have done that quite a few times when the windows, liftgate, headlights, car voltage rails, etc were acting up.
And if you don't have it, get a code reader to see if there are any codes. This car is produces a ton of codes and problems almost always produce codes. By contrast, my wife's Audi Q5 has hardly any issues and very seldom produces any codes, despite having a lot more tech features.
Dmac904
Jacksonville
Explorer ST
Did you find a fix? Mine is doing the same.
EDWYER
The switch means nothing without the motor.
San Francisco
2022 ST
This is weird because it sounds like a position-sensing/tracking error.
Something has to denote the seat is at its limits. (A switch, a position on its track, a rotary sensor, etc).
If the motor were broken, it wouldn't work. If there is a dead spot in the winding of the motor, you both wouldn't be stopping at the same position. The fact that you can repeatedly use the seat means the switch isn't bad.
Now, what mechanism is used to determine what position the seat is in? I have no idea.
San Francisco
2022 ST
I found this out in the wild.
https://www.explorerforum.com/forums/threads/driver-seat-wont-lay-back.496851/post-3924208
That person did some things and got temporary comfort. Apparently this has to do with the saved memory presets feature, and can also be tangled up in multi-keyfob-saved presets in the car at the same time.
Someone also cured theirs by getting the dealer to replace the BCM.
This problem is highly searchable on the internet, and everyone says the same thing, so it is definitely shitty code that causes bad code to fail.
Unfortunately, yet another example of companies not caring what people have to deal with.
(I see 10yr old Escapes having posts about this too. Whoever wrote the code for the BCMs needs to be quartered)
BC76
Indiana
2020 Explorer Platinum
Same issue. Dealer told me the motor was bad. Didn't buy that story, removed seat back panel and unplugged the motor - using multimeter I determined it was not getting power after it hit 90 degrees. Ended up reclining the seat using 12V power from a separate battery applied directly to the motor. That seems to have reset the max recline limit and now it works fine including the memory setting after I set that. I’m assuming it is a software issue. But this was a relatively easy fix.
2020 explorer st
Quick question would you be able to make a video of this process? In having the same issue off and on for years.
Dmac904
Jacksonville
Explorer ST
Fix for the no recline issue.
I have had to perform the following to mine 3 times now, and it has worked each time. I am not positive of the correct combination or if it matters, but the following is how I have reset my seat.
It's possible a step can be left out or moved in sequence, but if my seat fails to recline today, the below listed is what I will do to regain functionality.
Car Acc to On mode.
Press and hold both 1 and 2 memory buttons (allegedly clearing memory)
Disconnect battery
Touch positive and negative cables together. (discharging BCM)
Depress the Brake pedal several times. (another method of discharging residual voltage)
Reconnect battery
Reset BMS. This can be done with FORSCAN or manually with the ignition switch and a series of pedal presses. There is a video online of this procedure.
Your seat should work again.
