R2D2's 2022 ST - KISS Build
way2far
Tampa, FL.
Just read through your build thread to ultimately feel the gut punch with you at the end. Sorry that happened. Glad your wife is ok.
What vehicle did you end up with?
SackLunch
Lexington, KY
FORScan Change: Amber DRL with/without White DRL
Module : BdyCM - Body Control Module
Method: Easy click select
Additional Change : If you don't want the White DRL
Module : As-Built Modules BdyCM
Change : 726-42-01 x4x4 xxxx xxXX (original value was 0303 and new 0404)
Status : Working as programmed.
Note : Feature works when the vehicle is running, during day time (when DRL is supposed to work) and when Headlights are in Auto.
Pictures of Amber DRL working with and without White one
Question for the professionals. I was attempting to make this change and went to write the 404 change. A warning came up on FORScan about incorrect checksum of data entered. Should I just continue?
t_fiki
EMT
Colorado
I was wondering if anyone else has ran into the issue after changing somethings on Forscan. I will on occasion have the vehicle say "Language set to English" shortly after turning the vehicle on. I can't do anything that reproduces it and I have tried returning everything back to the original settings. Any advice would be greatly appreciated.
