Downpipe Installation
Who would be the best bet to install 3" downpipes on my ST? I know I am not set up to do it so I was thinking letting the Ford dealer install them along with the Magnaflow exhaust. Any other thoughts?
Troy, MI, USA
I think most exhaust shops would be equipped to do it. From talking to FenFab (who installed mine), you need to drop the subframe slightly, which supposedly gives direct access to the bolts. Making it easy to get on/off. All of this requires a lift, which most of us don't have in our garage. That being said, guys have done it in there driveways/ramps. A shop shouldnt charge you more than a few hours labor.
Grosse Pointe, MI, USA
Brett told me the same - a Ford engineer recommended that as the easiest route. He may make a step by step install video with Fat Guy Builds soon.
JordonNyler
Active Duty U.S. Navy
Jacksonville, FL, USA
21 explorer st
Which location in the downpipes did the O2 sensor spacer get installed?
I would love to see a install video.
There's some on YouTube which at least show you what needs to be done.
LoCarbST
Firefighter
Orlando, Florida
Just did my CVF downpipes yesterday in my garage, on ramps. No problem accessing the 3 E22's, lowered the subframe about an inch and got the 4th. 2 hours start to finish. Highly recommend just doing it at home if you have the means. Save some cash!
How high did you lift the car?
LoCarbST
Firefighter
Orlando, Florida
I backed the front wheels on to the ramps. Only about a 5-6” raise on the front. Plenty of space to slide under and work. I did notice that if you position yourself perfectly, there is a view of the “hidden” E22’s that you can see through the subframe. Made it a lot easier to view the socket to E22 bolt connection.
