Disable Auto Start/Stop on 2025 Explorer ST
#81
A word of warning for the 4D Tech adapter, I bought one of these in September. I installed it and used it for about 3 months with no problem. I started seeing issues with the touch screen not working, remote lock/unlock not working, and the tailgate not able to go up / down. I removed the adapter and all of the issues went away.
Did you contact the company for support? There have been almost no complaints about them.
Caster
I had a 4D tech on my 25' and it lasted 3-weeks before it failed. By the time it failed, Autostop Eliminator finally came out with theirs. I bought the Autostop Eliminator and all has been well since then except for certain over the air updates messing with it to where you need to unhook the negative cable for a few minutes to reset it.
msrobi
Seffner, FL
Yeah, 4D Tech seems to be giving me the run around on support. I won't make the mistake of buying from them again.
Gadgtfreek
#84
I can vouch that I have used AE on four different vehicles, and they have been great.
#85
On my 2026 ST, there is no PSCM listed in the modules list so I could not try that method that has been successful for other Fords. The only modules that have any sort of setting is BdyCM and APIM. The BdyCM toggle for Auto Start-Stop does indeed work but unfortunately, the battery light is illuminated on the cluster. There are no DTCs triggered though and it doesn't seem like any other aspect of the charging is affected. I'm keeping it for now until a better solution can be found.
SoCal
#86
Buffalo, NY, USA
#87
Ooooo 26?! Fancy. I haven't been lurking the forums too much so might have missed you post it but congrats!
#88
Thanks. My 2020 was rear-ended and totalled (to my surprise).
orrs2000
OH
#89
Any updates over the last year to permanently deactivate the start/stop without a tune?
Gadgtfreek
#90
Maybe I'm reading you wrong, but the Auto Stop Eliminator takes it out and works fine. Been on mine since I bought it. You dont need a tune, you just install the harness.
MO
2026 ST AWD
#91
Cdubya,
If you are a ForSCAN user, you can skip my post, lol.
AutoStop-Start Eliminator installed in our 2026 and it works perfectly. Initially, I had a small issue with a "Hill start assistance unavailable" alert. It took a couple of tries but the device works flawlessly now. Method has been described in other posts but bears repeating: Unplug the ASSE harness, disconnect the battery for 20 minutes, plug in the harness, and enjoy. Now the display reports "Autostop-Start disabled by switch." when the engine starts.
HTH.
todd-95B
Twin Cities, MN
2024 Explorer ST AWD
#92
Found this thread by doing a search for "FORSCAN disable start-stop"
I'm pretty sure I have it figured out.
As others have mentioned, you have to update the PSCM [Power Steering Control Module].
BUT... There's no 'Easy' mode.
So just to be safe, I created a backup of the module before doing any editing.
After I was done, I took mine out for a spin using both 'Normal' and 'Sport' modes with no negative effects.
My ST is pretty much optioned up to the max, but without the 360 Cameras due to a recall at the time.
I confirmed that auto-cruise works fine, even the lane keeping still works and will 'nanny' you if you don't keep your hands on the steering wheel.
INSTRUCTIONS:
Open FORScan on PC
Turn Ignition ON. *NOT Start
Click ‘Connect to Vehicle’ icon on FORScan. *A Warning pop-up will appear, click OK
FORScan will show a list of Saved Vehicles or start a scan for a new vehicle
At end of scan will be prompted to ‘Save Vehicle’ if new
Click on ‘Configuration & Programming’ icon, below the Wrench icon.
FORScan will show ALL modules in both ‘AS BUILT’ MODE and ‘EASY’ MODE
Go to PSCM [Power Steering Control Module] > AS BUILT > ‘Run Service Procedure’ *Warning Pop-Up
FORScan will display all PSCM modules in hexadecimal format *Don’t change anything!
At bottom of screen choose: SAVE ALL > .abt file > Destination > Save > then STOP SERVICE PROCEDURE
*You now have a back-up of all original default settings in the PSCM modules if it needs to be restored.
Go back to PSCM [Power Steering Control Module] > AS BUILT > ‘Run Service Procedure’ *Warning Pop-Up
Look for:
OEM Setting
730-03-01 xxxx xxxx 013B
Change to
730-03-01 xxxx xxxx 003B
From other notes... Guessing:
730-03-01 >> Auto Stop/Start Section
00 = Disabled
01 = Enabled with Angle Inhibitor
02 = Enabled without Angle Inhibitor
Then in that 'block' select 'write'.
commanded to save, got a checksum error message and accepted that as OK
After it completes, you will be prompted to turn off vehicle and restart.
Click the ‘STOP SERVICE PROCEDURE’ icon. *Square Stop icon
Then disconnect from vehicle.
Go out for a test drive.
Confirm that everything is working as it should.
Auto Stop/Start should be OFF and STAY off without pushing button.
I noticed that when I come to a stop, the icon displays in the lower right dash area, but the engine does NOT stop.
JPony
2026 ST Explorer
#93
Cdubya,
HTH.
Thanks! I'll be getting this.
Haddezz07
2026 Explorer ST black
#94
INSTRUCTIONS:
Open FORScan on PC
Look for:
OEM Setting
Change to
00 = Disabled
Reviving this thread, to confirm this works. My 26 ST rarely ever turns off. I have owned the vehicle for about 4 months and i think its only turned off while stopping about 5 times. However my buddys does it all the time. I have no tune , no mods just intake and awe exhaust. I do drive on normal most of the time, as well as the ac set to low and speed 2-3. Also the stop assist as turned on as well.
Seffner, FL
Check your battery percentage. A low battery can also keep your start / stop from working. I know, the battery in my 2025 goes from ~80% down to ~30% after sitting on AC power for only about 2 minutes.
Shepherdsville, Ky
My 2025 does this as well. It has had no changes, just like it came from factory. No complaints, dislike the stop/start feature
Seffner, FL
Check your dash, if you see a grey A with a slash through it when you come to a stop, it means the system has disabled it because either:
1) The HVAC is running too "hard" and stopping the engine would be counter-productive (this could happen if you're having 110 degree days)
2) It has determined the battery is not healthy enough to auto-stop the engine
To test the second, I suggest charging the battery to full overnight, then drive it and see if the stop-start is working. If it does, it likely has to do with your battery.
