TRQ Strut & Spring Assembly Set
St Augustine, FL
Hi all!
My ST needs new struts in the front and I wanted to just change out the entire assembly because I am hearing some clunking which sounds like the bearings might be bad as well. So I figured it would just be better to change everything while I am doing this. Has anyone used the TRQ brand Strut and Spring Assembly set to replace the stock setup? If so, how does it feel? Equivalent to stock or a worse ride?
Thanks in advance for the help!
https://www.1aauto.com/2020-22-ford...ly-set-trq-sca29107/i/1assp03080/7477144/2021
I also see that RockAuto has a set, but I am not sure if these are motorcraft or aftermarket, and if these are equivalent to the stock ST setup. Any thoughts on these is appreciated as well.
I have not run TRQ but they are a budget brand. Some complaints about noises after installing and not great longevity. If you can get a spring compressor, swapping just struts is not a tough task compared to replacing the whole assembly.
I recently replaced mine with oem from Rock Auto and they were reasonably cheap. I have lowering springs and a spring compressor so it was a no brainer for me.
Good luck whatever you do.
T
St Augustine, FL
Thanks for the feedback. I had considered doing that as well and just replacing the bearing in the process, but the I have never compressed a spring before, so I am a little intimidated by it. Dont want to shoot a spring through the ceiling LOL
