EDWYER
Had my OEM 20 driver side wheel rash repaired by a local shop. Came out great. For anyone needing it around Charlotte, just PM me for the info.
Fabbed up an air deflector between my IB sub vent and the lower rear bumper. Since I removed the oem air deflector the rear bumper was all floppy…this firmed it up and deflects the air at the same time.
D
Deleted member 23258
Guest
If it was mine the first oil change would have been done a while ago. Most people change at 5000 miles or even less.
Yep, I do the 5k thing.
MO
2026 ST AWD
Mines done 6650 miles and still has 28% oil life left before it's first change is due LOL
@Nianiamh,
I have not checked but can the change interval be set by the owner? If 6,650 miles is 72% life then the interval is around 15,000 km which seems really, really long to use the same 6 quarts in a turbo engine (imho). The snow must be just about gone in Winnipeg now so it's finally oil-changing season. [biggrin]
Winnipeg
Explorer st 2025
@Nianiamh,
Not sure if the interval can be changed yaself Mate, had a 2015 sport and that had a variable service timer n all think it was just over 16,000kms before it started a countdown to needing a oil change (y)
Nunya
After data logging and revisions i got my final ZFG 91 tune. It feels amazing absolutely worth it. Every time i submitted any request for base tune or datalog reviews adam had a tune for me within like 12 hours. I couldn’t be happier. Wife said daily driving “normal” mode feels “silky smooth”. Spinning the wheels while building boost on the launch makes me smile. Can’t wait to try e30.
Installed horsepowerfabrication.com’s brand new, just released today radiator shroud. Great part to hide part of the ugly stuff under the hood. IMG_0607.jpeg
MScott821
Wallingford, CT
@Nianiamh :
You are a better painter than me!!!
When you get a chance, jump over to the "Exhaust Tip Questions" thread where you will see @drcookie , @Leadfoot and I have been discussing exhaust tips on the ST's. I loved the looks of @drcookie's application of WESDON Stainless Steel Tips so I got some for me. At this point I am not 100% sure which complete exhaust system upgrade I will end up getting (know a lot about BORLA from previous 2 Mustangs but also love the Thermal R&D 2.5"s) in the future.
My main issue is the "Fake Engine Noise" that is pumped into our interiors. I do not want to install a really nice system until one of our more learned members here figures it out or FORD brakes down and tells us how to PERMANENTLY disable that silly nuisance WITHOUT causing collateral damage/problems to other systems in the vehicle.
Until then, I have the look I wanted.
Finished view:
During conversion process: stock left side tips there really look cheap compared to new Wesdons on the right.
Use Forscan to permanently disable "fake engine noise"
MO
2026 ST AWD
@UNBROKEN,
Very nice! That cover is on the must-have list now. Thanks for posting that photo.
St. Louis
Big shout out to @ebentz30. He went above and beyond selling me a set of black spoke stock 20-24 ExST wheels for my 25.
He gave me a great deal and helped me more than he knows.
Thanks again Eric, this forum/community is great.
ebentz30
Little River SC
No problem at all. Paying it forward.
I added a Banks iDash display monitor to my 25' ST when it was new in mid- 24'. I couldn't get all the parameters I wanted and expected out of it like oil pressure and trans. temp. .
I finally called Banks last week to talk about it. It turns out the the latest Banks iDash called the iDash Pro will infact display my missing parameters and a whole lot more. Basically my original iDash was now obsolete. They threw me a deal and sold me the new iDash Pro for $150 and provided me with a return shipping label to send my original back to them. I got the iDash pro on Monday and swapped it out from the original. I customized the display to show the parameters I wanted to track and all is now good !! It's freakin awesome.
- Calculated Engine Load
- Boost & Vacuum
- Oil pressure
- Battery Voltage
- Trans Temp.
- Intake air temp.
MO
2026 ST AWD
Caster,
Very nice. That's the info that Ford should have made available on the instrument panel.
This site is proving to be a den of parts temptation. :D
MO
2026 ST AWD
Hey, Caster,
Do you think the "iDash Stealth Pod Mount" for the Bronco would work in the ST? Banks shows the mount in the A-pillar in the Bronco and the ST A-pillar vent location looks very similar.
How did you mount your iDash Pro, please?
Thank you.
