2025 Sound Not Working
Houston, TX
On a few different random occasions my stereo would not make any noise. None. It didn't matter what source; radio, carplay, siri, etc... no sound at all would come through. The only way to fix it is to turn the car off, open/shut the door, wait 30ish seconds, open/shut door again and then restart. Has anyone else had this issue?
SoCal
Mine has done this a couple times, usually after a recent software update.
To quickly reset your system on the fly, press the physical power button 5 times in row. This will soft reset the entertainment system on the 2025+
This fixes the problem for me
S
Houston, TX
Thanks. I've actually tried the power button 5 times things and it did nothing. There must big a trick to it I am missing.
SoCal
There are two options for soft reset, shown below from Ford.
I think you need to press the fast forward button while holding the power down. The system should restart after that.
That's the way it's been on my 2021, but I read somewhere that had changed on the new ones.
Palm Beach, FL
Explorer ST 2022, Excursion 2000
This happens to me on my 2022 every once in a while. Very annoying, but if it happens, just do Power button+Fast forward until the display goes off.
S
Houston, TX
The 2025 doesn't have a physical fast forward button.
I'll try the other methods above the next time it happens. I tried these before but maybe I was doing something wrong.
JAX, FL
25 Explorer ST & 21 F150 PB
When I first got my '25 the process was hold the power for a while. But after an OTA update last year, that no longer works, but the press the power button multiple times fast is the way since that change.
phuxtick
Tomball
My 25 did this 4 times this morning - 7 rapid power button presses did the trick for me, but didn't think it would blank the dash too....what a stupid problem these things STILL have
PA
Dealership can update the ACM and DSP Modules to fix this.
