Transmission fluid change required for tune?
Sammedina1
Georgia
Hello all. Just joined and looking for advice from experienced tuners. I plan on tuning my 2025 ST and understand replacing spark plugs (to NGK Ruthenium) and engine oil (filling to 6.5 qts) are a must. I plan on a Livernois 93 Tune and will generally continue to use my ST as my daily driver. I'm seeing mixed advice regarding transmission fluid and filter change. Is this a must as well?
EDWYER
No.
Charlotte
2024 Explorer ST
The reason for the oil fill level is to prevent the pickup tube sucking air and frothing under spirited driving/acceleration. If the oil is on the lower side its possible for this to happen where you get dips in oil pressure at the very wrong times when its needed the most. Fenfab makes a aftermarket oil pan with extra capacity and baffles that pretty much solves that problem. Otherwise keep an eye on your oil level , keep it always on the high side.
Never heard of trans fluid changed with a tune. I can say from the research of reading forums and watching vids on this vehicle, better to change the fluid on the early side like 25K miles especially if you enjoy getting on it or with a tune. The transmission is hard on the fluid it seems. I upgraded to the PPE aluminum transmission pan early and whatever fluid that came out I replaced with Amsoil ULV. That was like 5K miles and I plan on doing another dump and fill at 30K miles. Also never have a shop do a power flush with the machine on these transmissions. I don't know why but many folks in the know here recommend against it.
Change, no…but I’d recommend having the fluid level checked. They’re notoriously underfilled from the factory and that can affect WOT shifts, particularly the 1-2 shift.
S
Sammedina1
Georgia
Super helpful...thank you. I won't be hitting the drag strip anytime soon, but will be sure to be more vigilant about monitoring my engine oil levels. Will also have my transmission oil level checked...your mentioned of the STs coming in with low from the factory is a consistent one.
S
Sammedina1
Georgia
Thank you. Just made an appointment the have all my fluid levels checked!
After my 1200-mile oil change, I added another 1/2 qt. Intend on Transmission service every 50k miles.
Don't forget the intercooler.
S
Georgia
Thanks for the call out re the intercooler. From what I've gathered it makes a real difference with overall performance. Do you believe this is a must have for a daily driver?
Combatvet
I'm not tuned yet, but honestly haven't noticed any difference with the CVFab Intercooler, but again I'm not tuned, and it's winter time..
I think its a must have even on a bone stock vehicle.
Combatvet
My installer said he was shocked at how small the OEM Intercooler was.
