Rattle noise in front end?
Funnbobby
What did they do to fix your drivers side wind noise??? Thanks.
bnsutton
Alabama
They adjusted the drivers side door in some way that worked. It is much quieter now at highway speed. Many things can affect this so we’ll see in the long run.
Sinker
Virgina
23 Explorer ST
It may not be the strut itself, but rather the strut top mount. Seems this is a common failure point on these Explorers. I think I had the same problem as you... it sounded like a dull knock when crawling at low speed in a parking lot, but no issues with ride quality. Fortunately for me, the dealer replaced front struts, mounts, and links on both sides under extended warranty at around 40k miles when I was having this issue.
Hey I know this is a little after the fact, but I'm curious which extended plan you had for this work? I just bought a 23 ST that might have this issue and I'm am debating on keeping the dealer ESP or getting the Ford ESP.
Don’t mean to but in but, I’d stick with Ford. I bought an ESP from the dealer and the first time I went to use it, they told me the part wasn’t covered! My 4WD module went and I ended up having to pay out of pocket! Needless to say I was pissed and canceled it. I opted to spend the extra $800 and got the Ford ESP. JFWIW
Buffalo, NY, USA
Once again coming from the dealership side.. and no longer at the ford dealership side.. If you are going to purchase one.. always pay the little extra for factory ESP. Always.
Buffalo, NY, USA
#26
The above comment was for you haha Im sorry
SW Louisiana
I'm pretty sure mine was with Ford... I remember seeing it referenced in my Ford Pass app.
Hull, GA, USA
#28
Has anyone had a front strut make a clunking noise when the temperature gets in the 40’s?
23 Explorer ST
I had that issue. Had struts replaced but the clunk was still there.
Dealership found the end links had slight play and replaced both sides. No more clunking.
Supreme Ruler
EMT
Washington State
I had a mystery clunk from mine; it ended up being a loose front sway bar end link. The torque had to be to spec, not just two ugga dugga's.
One of my front swaybar mounts ran dry and wore too big. A new set of bushings solved it. This was with a Steeda sway bar.
