2022 Explorer ST Build
Automovil
Automovil
Chicago
Thread Starter #21
Just extend the slots for the oem camber adjustment…takes just a few minutes with a carbide bit on a right angle die grinder.
That's what I will end up doing when i get around to it. Have to have plates welded to my front struts to fix camber up there.
Depending on how much camber you need to dial out you can elongate the top holes on the strut too. Welding the slotted tabs on is definitely an option but slotting the holes is fast and free.
New Jersey
2021 explorer st
You have a picture of the wheel? I'm thinking of getting a new steering wheel.
Automovil
Chicago
Thread Starter #24
Yes, Here is mine !
The guy makes then in different colors Regular / Forged Carbon / Heated & Non Heated
Yes, Here is mine !
Is that from Cody Ball?
Yes, Here is mine !
Unless you're 16, just say NO!
