What to use on the faded exterior black plastic trim pieces?
BIMGuy
Jax, FL
2020 Explorer Platinum
I'v read reviews on the chemical guys plastic restorer but have never tried anything to compare it to. What are you crazy detailer folks using, and how long does it last?
Meguiars Ultimate Black lasts as long as any of the others and is readily available at pretty much every parts store in the country.
Canby, OR
I used Exoforma and it works great.
Second Meguires stuff, works amazing!
Whatever you use, stay away from Cerakote! It will ruin your trim. Though some have had good luck, a lot haven’t, including me. It turns chalky white. I used the Exoforma on my old Ranger and it works pretty good. I did it about a month ago and it still looks good.
B
BIMGuy
Jax, FL
Thanks everyone.
Moorestown, NJ
@BIMGuy Vasoline. Just a little bit goes a longgg way.
DC Area
2020 Ford Explorer ST ... 2003 Lincoln Aviator
Might need one or application to restore color then after use regular when car detailing or washing .
Vaseline will degrade automotive vinyl. A petroleum product sitting on vinyl in the hot sun is a recipe to make things worse. It'll look good for a short while, but is not in your vinyl's best interest.
I'm someone who watched a newer dashboard crack away when Vaseline was used. Granted this was a long time ago and things change, but I could never make myself give it a shot.
I'd recommend a product designed for just such an application.
