Cams in Motion + Remove "Full Screen Not Available" black box - 2025+ only
Nightshade
Firefighter
Alberta, Canada
Good news for those with 2025+ Explorers (will be all trims). Those who are wanting to enable cameras at speed and are encountering the issue with the annoying black box in the middle of the screen that says "Full Screen Not Available", the changes below allows you to enable your cams while you're in drive and at any speed! All you have to do is press your camera button in the buttons row, right next to your volume knob and it'll work!
APIM -> 7D0-02-02 -> xxx*-xxxx-xx--
(If your current value is 0 then change to 1, 2 change to 3, 4 change to 5, 6 change to 7) NOTE: Reboot APIM after the change.
**Always remember to make a backup of your APIM module before making any changes, just in case and to be safe.
--Cheers!
Gluestick
Nashville TN
This worked great. Thanks!
Marietta, GA
2025 Ford Explorer ST 4WD
@Nightshade: Thanks. I made that change and the rear view camera works great. I cannot see the front camera or other modes though. Is this normal? My camera select is rear or trailer - all other greyed out.
Nightshade
Nightshade
Firefighter
Alberta, Canada
Glad to hear! Yes front camera won’t work while in drive (doesn’t work in F-150s) either except Raptor trim, just a limitation on software (only works in Baja mode on Raptors). Side cameras can work with a change however I wouldn’t recommend it. The angle of it on the ST is pointed far down while on the F-150 is pointed straight out for better viewing; my guess is because the F-150s is a bigger and spaced out. Your hitch mode should work and trailer will work when your trailer plug is plugged in.
