Rear Axle Seal Leak
Iowa
2022 Ford Explorer
I have a weeping rear axle seal. 81,000 miles. Is there a known procedure to remove a rear axle without requiring an alignment or replacing the torque to yield bolts?
is this on the driver's side? Did you have the rear diff mount replaced recently?
B
Iowa
2022 Ford Explorer
Passenger side. Rear Diff bushing was updated in April or May this year.
I only asked because if the driver's side, it may be related to the bushing replacement.
It is really up to you if you want to replace all the one-time-use bolts and axle nut. I would imagine the process would be similar to how we would do a rear spring change except you dont touch the spring:. remove shock, disconnect sway bar link, disconnect upper control arm from knuckle... should allow you to tilt down the knuckle for axle removal. However, the service manual calls for removing the entire knuckle. And I hope it just needs a new seal and not a sign the diff carrier bearing is failing.
B
Iowa
2022 Ford Explorer
I hope it's not a bearing going bad as well. I've had this thing in several times for rear axle clunking though, so could I'm going is a torn seal from the 2-3 sets of rear axle replacements.
Are you a Ford technician?
B
Iowa
2022 Ford Explorer
No, sorry.
2022? Still under warranty?
No, sorry.
Negative. 81,000 miles. I did check my paperwork and It was April 2024 the dealer replaced all the axle seals and circlips to do the bushing recall. Maybe they will step up and fix their work. However I am doubtful they have a monopoly on my area and are known for poor customer service.
the technical sheet for the bushing change only calls for the drivers side axle to be removed and it’s seal to be replaced. But if your work order says they had replaced the passenger side too, then you have a good argument that it may be a reinstallation issue and get it comp’d.
Pyro_1284
Whittier Ca
Should.
Negative. 81,000 miles. I did check my paperwork and It was April 2024 the dealer replaced all the axle seals and circlips to do the bushing recall. Maybe they will step up and fix their work. However I am doubtful they have a monopoly on my area and are known for poor customer service.[/Q
Should be 2 year warranty on parts and labor done by the dealer.
B
Iowa
2022 Ford Explorer
Well I took it in this morning and they did not get it tech to inspect it till 5pm. Had to leave it overnight Got a F150 XLT for the night.
