(Resolved - Sound returned on its own after a full day.)
I was able to turn on Amber DRLs with my 25 ST, but I was only able to get it to work through the (As Built) BdyCM Config, I couldn't find the option for the "Right/Left Front Turn Lamp Usage" in the BdyCM.
I used the Livnitup - 2025 Explorer Spreadsheet with Forscan to find the correct setting, but the interior sound for the turn indicators no longer works once enabled.
(Maybe it will magically come back after a few power cycles?)
Previously with my 22ST, I was able to use just the BdyCM and I didn't lose any sound.
Does anyone have any ideas to enable the sound and keep the Amber DRLs?
Sound came back after a day. No issues with those 2 changes.
Changed 726-43-01 from [x2x2-xxxx-xx--] to [x1x1-xxxx-xx--].
I also changed the "Using DRL with Turn signal" from Inhibited to Allowed in the BdyCM config.
The Amber DRLs only work when the vehicle is in gear and not parked, and only during daytime (Or when the daylight sensor picks up light from a flashlight or something).
- Show All
