“Creaky” steering.
BorrowedTime
Jax, FL
Hello everyone,
So…we have some “creaky” steering going on with our 2020 ST (32k miles). It is noticeable at a stop or while moving at slow speeds. I’m sure it’s there at higher speeds but we can’t hear it due to wind noise, etc. I had my wife turn the wheel back and forth while in the garage with the hood open and engine running, and I’m almost certain the steering box/knuckle appears loose while hearing the noise. It might be something loose on the power steering rack as well. Not 100% sure at this point but it is noticeable enough to be embarrassing at slow speeds in parking lots and so forth.
Has anyone else had a similar experience? If so, what was your issue and subsequent solution?
Thank you in advance.
Regards,
Joel
Hello everyone,
Regards,
Joel
I have heard of this problem happening to anyone before. Are you still under warranty?
B
BorrowedTime
Jax, FL
Unfortunately, no longer under warranty. So, this is a known issue to occur in rare instances?
No, I’ve never ever seen this issue from my all the time I’ve been around the forum and all the groups.
B
BorrowedTime
Jax, FL
Well, at least that’s a good thing on one hand. I’ll report back once I figure this out.
B
BorrowedTime
Jax, FL
Reviving an old thread for the sake of closing it out for anyone else searching for this issue. Obviously life got in the way of responding in a timely manner…
So…this was the result of a “worn out” steering rack and various front suspension bushings (at less than 40k miles..). Makes me suspicious of an unreported collision of some sort. Anyway…we purchased from Carvana and convinced them to cover the repair at the local Ford dealership. Vehicle has been perfect ever since.
