Timberline Skid plate
Philadelphia
Mine arrived this morning
Put it on late this afternoon
And got it at the 150 price vice the new 250
Wholly cow
Did you get a set of M10X25 bolts and M10 U nuts with yours? Wanted to install last night and they seem to be nonexistent.
Nassau County NY
received mine. old price. hardware intact. As soon as its not 95 degrees ill install it.
Yup all the hardware wrapped up in a bag
Greywolf
New York
2022 Ford Explorer, ST
Thread Starter #65
I just received mine after a 4 month wait. Box was open and only thing inside was the plate. No hardware. Can anyone tell me what exact hardware I need to go buy to install this thing.
I don't
But the website on accessories lists the parts included ...might be able to get the parts bag
https://performanceparts.ford.com/part/M-5018-EXP
Download the instructions...it has parts list
Ricky
Sunnyvale trailer park
#67
Contact Ford Performance at: [email protected] with your order number. They will send them right out. I had the same thing happen and received the bolts 2 days later from Ford.
Greywolf
New York
Thread Starter #68
OK so I bought it from CPC racing which in all honesty are being really great about it they wanted the delivery britches that showed the box was open and they’re going to try to get me the bolts. But I don’t feel like waiting.
Does anyone know the exact dimensions of the bolt the instructions only says M10 X 25. I need to know the pitch, and if they are hardened or not.
Thanks much
I don't
Thanks much for this. And honestly that’s exactly what I did after making my request on this forum. The only thing I can’t tell is what is the length of each screw? I know that they are M10x25 but what length are they?
Thanks much
Iirc about an inch in length
But 3/4 would easily work
The 2 rear bolts self tap into the rear trans support brace.. it's scary..
I shoukd have tapped them
But after I cleaned the holes real good
Then went in with moderate effort
Central Cal
Finally mine showed up at my local dealer yesterday. They almost lost it but luckily I went there to check on it and they found it (in area to be sent back-??)
BTW- what is the little fabric w/velcro and tie wraps for? It may become obvious when I install but thought I would ask if anyone knows. Thanks
EDIT: Never-mind... found the instruction sheet on line...
I was going to say. It's in tye notes to wrap the trans line,
Other than that. Did it go one ok
Greywolf
New York
Thread Starter #72
How did the 2 bolts that go under the trans crossmember bolt in? Did you need to tap the crossmember holes or were they already tapped?
No..I cleaned the holes out real good
Then sprayed some wd40 up in them to help with friction
But any light oil would work
Then started bolt really slow and straight and then would go in 4 or so turns Then back it out and blow out hole, then did that until it was fully seated
The bolt will cut tye threads and it's gets really tight...like your going to break the bolt
Hindsight. Tapping it would be less concerning
But if you tske your time they eventually cut the threads
Central Cal
Yes, went fine. Two rear bolts went in fairly easy. The clip nuts were more difficult, very tight. Trans line already covered and out of the way. (2023) All good.
I found the clip nut a royal pita as well
Got real tight,right before they were flush and torqued
I don't think they are going to vibrate l
Greywolf
New York
Thread Starter #76
Wondering if this was because of the hardened version of the Loctite that was already on the screws. This type of Loctite softens up during the tightening process making it harder to tighten than rehardens again later on.
When I use bolts like this I wire wheel that crap off and then reapply Loctite in liquid form and torque to specs. clip nuts should not present more resistant than regular nuts.
I agree that blue crap is tough
South Palm Beach, FL, USA
#78
Finally received the skid plate! Ford cancelled my order using points. I saw it on JEGs for $180 so I ordered it back in Nov 2024. As expected, it was on back order. Anyway, I installed it tonight and all the appropriate hardware was included. Word of advice when installing, tighten the rear most bolts first as they are threaded into the aluminum tranny mount carrier. The fit is not perfect and there is a risk of stripping the threads in these mounting locations. One started to strip as I tightened the midpoint bolts first. I was able to save it, but you will get to 18 Ft/Lbs. prior to the skid plate mating with the tranny. mount. Of course, Ford added the blue loctite so getting the other 6 bolts in gave me pause but worked fine. Just to get them in was way over 18 Ft/Lbs. Now oil changes with the UPR drain will be a super-fast! Having that opening also allows you to inspect any leakage from the O rings on the axle to the driver side front. After install I did find that some pesky rattle on initial startup went away. Yay!
jeg11010
Connecticut
Installed mine tonight. No issues. Initially started forward and worked my way back but then the 2 rear bolts didn't line up with the holes. So I had to loosen the front 6 enough so there was some play in the skid plate so I could get the 2 rear holes lined up. Then everything lines up and I torques them all down to 20. It's no wonder some of the online parts places are charging an arm and a leg for shipping. The box is massive.
Indianapolis
#80
Any issues with installing it on a 2025? Or should we wait until the new Timberline comes and see if anything changes?
