2025 Ford Explorer Order Guide
JAX, FL
25 Explorer ST & 21 F150 PB
Interestingly, no mention of 360 degree cameras and now can't find any mention of them on the https://www.ford.com/suvs/explorer/ site as a feature or an option. But at least it doesn't say deleted like the 2024s.
Sumner County TN
2024 Ranger Raptor
I'd think its there because you have bluecruise. AS for the Sync type, says in upper section applecar play/android.
Maybe check your order list under the 401a package.
Fly Ty
NY / NJ
It’s under “Ford Co-Pilot 360”.
JAX, FL
In the F150s recently, Ford Co-Pilot 360 did not include 360 degree cameras. The Co-Pilot 360 is radars/sensors only. The cameras were an additional option. If it includes them here, that would be great.
Fly Ty
NY / NJ
I checked on the Ford website. I guess they added it.
JAX, FL
yeah, just found it too
JAX, FL
Fly Ty
NY / NJ
JAX, FL
What is a “Blend Date”?
It is the date the production line has the parts to begin the build, which is usually completed the next day.
Fly Ty
NY / NJ
Ok, thanks for the info!
20 Platinum
I believe the 1.0 didnt have the 360 camera and 2.0 does
f1xedgear
Mine went into production yesterday (6/12), original build week was 6/17 and I have a blend date of 6/22.
Fly Ty
NY / NJ
Finally got some movement! No window sticker yet.
JAX, FL
If you are truly in production, a window sticker had to have been generated.
Fly Ty
NY / NJ
Oh ok. Well, hopefully soon.
Bloomington, Illinois
2025 Explorer ST on order.
Where does the window sticker show up? Or where can you look it up at? Mine shows in production with a 6/14/24 date.
Thanks!
JAX, FL
Thanks!
Go up to post 128 and use one of those URLs but use your VIN provided to you by your dealer.
f1xedgear
I had read elsewhere that once a date appears on the "In Production" step, thats when the car is actually being built. The window sticker will be available a bit before that point though so you can figure out when it should be done by the blend date code. "In Production" without a date just means it has hit the factory build queue.
Fly Ty
NY / NJ
Thanks for the info. I guess I’ll see something soon.
