Hey guys anyone here used the Lethal Performance springs.
I have Steeda now and am looking for a bit more drop.
I don't tow or go off pavement, so I am looking for the best drop while keeping the 21-inch stock wheels.
Thanks.
 I have Lethal springs installed and went with them for a few reasons. There were only 3 manufactures at the time with springs, Steeda, H&R and Lethal.
Steeda's drop wasn't low enough for what I was looking for.
H&R was low enough but had coil binding.
Lethal was low enough with no coil binding.
My first set of rear springs from Lethal didn't have the correct winding on the bottom causing them to shift to the side and make noise against the lower control arm. They have revised them ans I have the initial test set that has corrected that problem. I am please with the drop and ride control.
Eibach has progressive springs like H&R and will encounter coil binding. Unlike H&R, the Eibach kit does come with noise isolators on the rear springs where they will bind up..
