Stop wheel hob
Panama
Could you advise me on the order of parts I should get to avoid the wheel hob on my 2020 ST.
I'm thinking about this as a first option.
Subframe Bushing Support Kit
but I would like to know your experience which is the best so I don't waste my money
Buffalo, NY, USA
Confused.
I think you must mean wheel hop. If so the Steeda bushing kit is a good start.
FuriousST
Panama
perfect I will buy them and then what do you think should be the 2nd option to buy
Toe links, vertical links and bushing brace kit. Do it all at once.
www.fenfabrication.com or Steeda…both are great parts.
FuriousST
Panama
Perfect
FuriousST
Panama
FenFab bushing braces for all subframes…I’d bet money so do Steedas.
The Steeda kit will work for all subframes you'd find under an Explorer ST.
Fairfax, VA, USA
How do get the subframe part number?
Steeda says that you need to call a ford dealer parts dept with last 8 VIN to determine subframe version.
I was just looking at this yesterday to decide which parts to get.
FuriousST
Panama
Thanks very much
United States
For vertical links, you have a couple options, depending on your budget. FenFab makes a very nice billet vertical link set for I believe around $350.
If you want something a bit on the cheaper side, $100 will get you the billet aluminum inserts that bolt into the factory vertical links and stiffen them up considerably. Steeda makes them and they have a very informative demostration video on their website. Not quite as good as the FenFab option but it comes close for less than a third of the price.
I’ve had both. The FenFab are worth the difference. The Delrin bushings make a big difference. Steeda inserts are way easier to install though.
FuriousST
Panama
This is what I bought to start
United States
Bushings are definitely a big plus here. I ordered the inserts yesterday. If they work, great. If they don't, super easy to uninstall and sell for $75 shipped then upgrade to the fenfab links.
FuriousST
Panama
Thread Starter #17
install Steeda parts
FuriousST
Panama
Thread Starter #18
With these two parts my wheel hob was immediately solved. I recommend it as 1 option for those who have this problem.
note: I should let you know that these parts make the car feel harder on the road. comfort is lost
