Bad CV joints
Vell
Kansas
2020 Ford Explorer
Hi. I just purchased a 2020 Ford Explorer in July. Had my 1st oil change last week. They informed me that my driver's side cv joint was leaking. Come to find out the passenger side had already been replaced before I bought it. Has this happened to anyone else. Did I get a lemon? I seem to do that alot. Ughhhh!!!
Common issue. If it's under 60,000 miles should be under warranty.
V
Vell
Kansas
2020 Ford Explorer
Yeah. Right at 50,000
Both fronts will fail at some point. The boot design has been updated on the replacements. Normal, covered under powertrain warranty, and super easy and cheap to do if you're out of powertrain warranty.
V
Vell
Kansas
2020 Ford Explorer
Yeah. The last owner had replaced one already. I just thought this was unusual for it to happen on a newer car. I've never had to replace them on any of my other vehicles.
It is unusual. They are faulty. Just another flawed part for MY2020 and early MY2021, like catalytic converter pipe welds, failing flex sections, and likely axle hub actuator leaks (as these cars pack on the miles).
Welcome to the forum.
Safety Harbor, FL, USA
Had my passenger side replaced twice now. First time at 40k miles and second at 50k miles.
Ashburn, VA
Passenger side replaced at ~32k for leaking CV joint under warranty.
85k and never had a boot leak. Just replaced both because the DS inner was starting to pop. After pulling the old the PS inner wasn’t far behind.
College Park, Maryland
Found this condition on Saturday - driver side. Going in for warranty replacement this Saturday.
