Wind/rattling sound near B Pillar
mjtobias
Wisconsin
Ford Explorer Platinum
Anyone else experience a rattling sound coming near the B Pillar when driving highway speeds around 50mph and above? Brought mine to the dealer this past week, and they installed a new A and B pillar trim, but the sound still persists. Any thoughts? Thanks!
It's usually the undershield making noise. The plastic retainers are garbage and come loose. Stainless M6 nuts with fender washers to replace those will solve that once and for all.
M
mjtobias
Wisconsin
Thank you for the reply! So for example, are you saying the plastic retainers which hold into place the keypad piece on the drivers side door need to be replaced with stainless steel ones?
I'm talking the cover underneath the car. At speed, the noise will seem to come from the door or the B-pillar but it's actually the undershield that's flapping around.
M
mjtobias
Wisconsin
I'm talking the cover underneath the car. At speed, the noise will seem to come from the door or the B-pillar but it's actually the undershield that flapping around.
sounds good! Anyway you can diagram which piece it is? Just bought my first Explorer a few months ago, so I’m new to this :ROFLMAO: Is this what you’re referring to?
that's it. Id replace all of those. I think there are 6-8 of them.
Texas Hill Country
2021 Carbonized Gray Explorer ST
Just fixed this myself after chasing the high speed fluttering noise. Some 1" fender washer on top of a M6 nut to replace the plastic retainer will fix it. I'm in Texas so I just used regular steel washers. Being in snow and salt country I would recommend you use stainless hardware. Ford uses essentially the same thing for several of the attachment points. It's another Ford engineering mystery as to why they use the crappy plastic fastener on some points and more robust nut and washer other places.
M
mjtobias
Wisconsin
Thanks! I replaced the plastic piece with stainless steel ones and bingo, the sound is gone! Amazing how the dealerships can’t figure this out.
2021 Ford Explorer
Hi, I have the same issue. How did you remove the plastic retainer? Is the center post threaded to accept the M6 nut?
Texas Hill Country
The plastic retainer is threaded but I think I had to sort of pry and twist them to get them off. The post is threaded and an M6 nut will thread onto the post.
philcwood
Houston, Texas
Look at the under carriage cover in the same area. The connectors come loose and that molded fiber piece flaps in the wind.
Central Cal
Just got back from a cross country road trip. The last few days had an extremely annoying rattle from the passenger side door area. Thanks to this thread it was an easy fix. One of the stud nuts that holds the heat shield and fiber cover had loosened to almost falling off. Tapping on the fiber cover revealed the rattle. Tightened up and rattle gone, several nuts needed a bit of tightening. Will probably replace the plastic "nuts" also as mentioned above. (my loose one was an actual metal nut)
It's sad that after several years the same problems are continuing to happen.
Geeromey
Louisiana
2022 Ford Explorer XLT
Thank you all!!! I would have never guessed it, but this fixed the issue. Both driver and passenger. I tried water test, tension test on door and windows, and nothing helped identify the issue. I was 100% confident it was the black pillar plastic (keypad) that was the issue.
Found this thread, checked the underbody, and found a number of loose plastic nuts and missing nuts on both driver and passenger sides.
For others trying to resolve the issue, it’s a very inexpensive fix and definitely worth the try. If you can find M6 nuts (not bolts) in a hardware store without help, you can do this!!
Start by using your hands to press the fiber underbody (feels almost like cardboard egg carton). There’s probably 10-12 connection points on passenger and less on driver (maybe 8-10). On the outside edge, below the front and rear doors, is where the crappy plastic nuts are located. It should be loose in this area (push fiber underbody up - any loose is too loose)!
Rip’em out! Pic below shows you can use small flatheads or long thin needle noise to release the clip, but it’s more enjoyable ripping out.
Get M6 nuts and big washers (pics below from Home Depot). I used 10 of each. Replace plastic nut with washer and nut. Use 10mm socket or hand and tighten. Repeat on both sides.
I checked all metal nuts and they were secure. All but 2 plastic nuts were VERY loose.2 completely missing.
Another pic of tools for the job. And don’t forget a nice piece of cardboard to lay on.
Test drive up to 65 mph and total silence afterwards.
Thanks again and good luck to others.
ps yes I’m getting galvanized or stainless eventually. Zinc was available and less than $10 total.
Explorer33
Explorer
I see this is a bit old but I just wanted to thank you for this! I'm not super mechanically inclined but the pics and explanation got me under the car to fix this and save a trip to the dealership. So satisfying to get back on the road without that annoying sound.
Illinois, USA
I don't know how it took me so long to find this thread...dealer has assured me that they don't know whats causing the noise and can not duplicate the issue I hear...ever...day...driving. Next trip out I'm picking this stuff up and tackling when I do the next oil change.
Marquette, MI
Thank you to all who have posted. I know this is an old post, but it saved my sanity!
Anyone having this problem follow the perfect explanations above. @Geeromey with the pics of the black pieces to remove was really helpful. Do what he says. I found it to work best with a small pry bar to break the round black plastic pieces loose, then yank them out with pliers. Replace all of them with M6 Nuts and Stainless Fender Washers.
Silence......... what a beautiful thing!
FYI I had this problem on a 2022 Explorer with 22,000 miles on it. What a terrible design.
