Looking for HPFP and tune e85
Thousand Oaks, CA, USA
Hey y’all! So my lady and I decided we want to run e85 and do a tune. I’ve been asking around and found ZFG to be reputable and one of the industry leaders. I’ve also heard that Nostrum has the best deals for HPFP. I’m having issues finding just the pump. Can anyone point me in the right direction? I’m just looking to get e85 gains since I have about 6 stations local to me that sell e85. Maybe in the future I may do more but for now I’m looking to keep my expenditures at 2500 or less.
ZFG will sell you the just HPFP, just the injectors or as a set.
pump https://www.tunedbyzfgracing.com/pr...-and-aviator-3-0l-high-pressure-fuel-pump-kit
injectors https://www.tunedbyzfgracing.com/pr...er-and-aviator-3-0l-nostrum-stage-1-injectors
set https://www.tunedbyzfgracing.com/product-page/2020-explorer-and-aviator-3-0l-stage-1-bundle
Honestly, your best bang for the buck is buy the set. then get a tune from ZFG to run full E-85, you'll be all in at about 4K, for the pump and injector set, the tune and the device to upload the tune into your vehicle.
By not doing the injectors with the pump, you won't get the full benefit of the HPFP. It would be like filling your swimming pool with a fire truck vs. from a fire truck that necks down to a drinking straw.
M
I looked at the links you sent but they appear to ONLY be the bundles. I remember a few months back I saw the injector going for about 750-850. XDI by itself is like 1400. I’ve searched google up and down but dialed to yield any results for just the pump.
Try looking thru the site yourself https://www.tunedbyzfgracing.com/
The links I posted take me directly to each item, but it may not work on your end.
M
Guess something is up with my side of things. I have looked up and down. Only pump I can find by itself is the XDI pump. All I can see are kits 1899 for pump and injectors and then just 1299 for injectors only. Not sure why I’m blocked from finding just the pump itself. I’ve even looked through the nostrum site and couldn’t find it. Is there a particular model number I could use to find this HPFP elsewhere?
The 1899 is just the pump, the whole kit is 3098
M
Omg I can’t believe how dense I am. Thanks for clarifying. So then the XDI pump is actually 400usd cheaper. So is the consensus that nostrum is the way to go then?
Yes the Nostrum is by far the better pump, you get what you pay for.
M
Awesome! Thank you very much
