Can’t change Speedometer in Cluster from kmph to mph
Osorio299
Bay Area, CA
Ford Mustang
Hey guys! New guy here, just picked up a 2022 ST, 400A packages, with only the wheel and brake upgrade.
Anyhow, loving the car so far, except that the speedometer is showing a very large KM/HR number and a very small MPH number.
in doing some reading of the manual and online, it says that I should be able to adjust this through the menu button of the steering wheel, yet the only option provided is “oil life”
Is the speedometer a setting only available on higher trim (401a?) or am I missing something here? Thanks for any help in advance
Ontario, Canada
Is the speedometer a setter only available on higher trim (401a?) or am I missing something here? Thanks for any help in advance
There is a display option under the menu accessed from the right side of the steering wheel. However, my Canadian version will not allow me to turn off the km/h when also displying mph. I noticed on the ST SUV Experience vehicles in Asheville that they only displayed mph. Good luck.
Kansas
2022 Rapid Red ST
Select Settings as shown on your picture by pushing the up buftton to get to that instead of Oil Life. Then you can select MPH.
O
Osorio299
Bay Area, CA
Ford Mustang
So.. you guys were right. The menu was right there, and I was able to change the speedometer to only show MPH. I’m a bit dumbfounded on how I missed it lol. Back to enjoying the car! Thanks guys
You have to go into display setup which is below settings in menus and uncheck km/h. If you scroll up and down there are several menu items besides settings which is only the oil life.
dfricke77
Eureka, MO
Hey, was wondering if you ever found out a way to only display MPH on your Canadian Explorer. I'm having the same issue. The one I bought was apparently imported into the US and I want it to display MPH only.
Tripper
Kansas
2022 Lincoln Navigator
I also have an imported vehicle that will not display mph only. Has anyone figured this out?
