3.0 Front suspension
Hauk1ter
Inver Grove Heights, MN, USA
I bought a crashed 2020 ST and I need an entire RT front Knee assembly. Does anyone know if the assemblies from a 2.3l are the same?
I also worry that the ST has sport tuned suspension and therefor different from other models
Does anyone have any wisdom on this issue?
Side question, I need to program the door code, is their still a master code hidden on the explorer to allow me to put in a new door code?
The difference in suspension should be the shocks, springs, and sway bar, and maybe stiffer bushings. But the hard parts like spindles, control arms, etc should be the same.
GORDO
22’ ST
There are some parts from a low mileage wrecked 21’ on on eBay, I bought a transmission from them to have an extra. They might have the parts you need.
H
Hauk1ter
Do you know the eBay store or person And thank you
H
Hauk1ter
So it sounds like I should not consider anything from a none ST
