Oil Brands you use?
Tx
What brand of oil do you run in your ST? ABE0CDE9-141B-4ED0-8F7D-FBAD8A0429FE.jpeg
Ahhh... another oil thread, I have my popcorn. I personally run Mobil 1 Extended Performance 5w30 but I'd never tell anyone that is the only (read best) oil to run. There are more than a handful of products that will be perfectly fine in the Exploder.
I change mine much more frequently than recommended even when running the EP and no one could tell me there is a better way. Pick a good filter and change your oil at an interval you are comfortable with. I send in an oil analysis yearly and have never found an issue in my engines. I'm too old to change my ways.
Nbk4t5e
San Antonio, TX, USA
Mobil 1 here as well.
Detroit, MI, USA
Mobil 1, every 5,000 miles.
Autoworker
Motorcraft Semi-synthetic. 5w/30 in the Explorer, and 5w/20 in the F-150. Every 5000 miles. Motorcraft oil filters also.
Sgt1411
BC&AZ
Has anyone heard or used Schaeffer Oil?
https://www.schaefferoil.com/
I ask because I never heard of it but was talking to some Police Fleet Managers at a conference who run large PIU fleets and since switching to Schaeffer their oil analysis is coming back with almost no metal particles. They are extending oil change times and continue to have very clean oil when tested.
Im going to try it on my next change.
2021ExplorerST#
Tx
Im coming up on 3000 miles and a avid 3000 mile interval oil change kinda guy. I thought about trying out some amsoil thats what i run in my diesel but went ahead and just have motorcraft everything in mind for now.
Autoworker
Oil technology has improved so much through the years you can get by with 5,000 mile changes, but you have to do what you're comfortable with.
South Palm Beach, FL, USA
Redline, has never let me down even in my track car. Expensive but imho worth it.
Tommy
Rotella T6 5W40, every 10,000 miles (use vehicle oil life indicator). Going to run T6 5W30 Multivehicle as soon as my stock is depleted.
Detroit, MI, USA
Why use a blend when full synthetics are available?
BTW isn’t Rotella mostly for diesels?
zdubyadubya
I run 6.5qts (per recommendation of ZFG tuning) of Amsoil Signature Series 5W-30 plus their EA15K43 filter and change every 5000 miles. I also run Blackstone oil reports with every change. You can check out the blackstone thread for results. Everything is running fantastic so far.
zdubyadubya
Anecdotes are like opinions as in everyone has one, but my dad has a 800hp 12V Cummins with over 200k he has run nothing but Valvoline Premium Blue (per recommendation of Cummins) in for like 20 years. The Shaeffer reps have been hounding him for years to switch to their motor oil because they supply his ranch/dairy with all of its hydraulic oils and gear oils. He normally changes oil every 10k, but dipped a sample for Blackstone at only 5k and chrome, aluminum, and iron were all at higher ppms than his averages. I'm not a motor expert and from what I've heard some advanced synthetics with alot of detergents can "penetrate" more and so maybe the oil was cleaning out crevices that hadn't been cleaned out before and thats where the incease came from, but i know my dad went back to Valvoline and his numbers returned to normal.
20 Platinum
+1 on Mobil 1
Las Vegas, NV, USA
it's really like picking your favorite ice cream flavor
if the oil is full synthetic and the correct weight, you're good to go
I personally use Kendall GT-1 full synthetic 5w-30
DaveG ST
Hurlock, MD, USA
Mobil 1 Extended Performance 5W-30 is my choice and I go about 10K between changes. I go 15K between changes on my other car
Blaster7Romeo
Western NC, USA
what are the oil weight factory specs? and how long in general till the change oil light comes on ?
(assuming there is one )
What brand of oil do you run in your ST? View attachment 8994
Well I did my first oil change at 974 miles with this brand of oil was I out of line here ??
I see a lot of owners are using mobile 1
Next oil change I maybe using mobile 1 myself
I’m going to change it every 3000 miles here on out I hope that’s cool….
When I dropped off my samples this week to Blackstone labs I asked if they saw a difference in oil types for the EB 3.0 and they said nope....
