Memory seat not remembering position
wb0hhm
Sioux Falls, SD, USA
I see several posts on memory seat problems , my problem is the same drivers seat keeps moving forward , have to slide back about
every time getting in vehicle.
had dealer service check , I think they just reflashed seat module
if someone has gotten this fixed for good , please Email me with information on dealer phone number or any information so don’t
have to reinvent the wheel , someone must know the fix for this problem
Ray [email protected]
waxian
PA
Did you ever have any luck with this? Mine is doing the exact same thing. I feel like it just started within the last 6 months to a year, and I have had the explorer since 7/2022 7/2020.
Jeppo
Davidson County, NC
Did you ever have any luck with this? Mine is doing the exact same thing. I feel like it just started within the last 6 months to a year, and I have had the explorer since 7/2022.
Oh? :rolleyes:
W
wb0hhm
Have not gotten it repaired , turned off the easy entrance feature and leave seat pretty much in one position .
waiting for somebody to come up with the answer I haven’t pursued it with the dealer for a while will check back before the vehicles out of warranty
Ky8530
Cleveland, OH, USA
This happens to ours also every so often. No idea why or what to do to fix. Dealer thinks I'm crazy.
London Ontario Canada
This happens on my 2021 Explorer ST and now my 2022 Explorer ST, same crap. Memory seats do not work correctly.
Ontario, Canada
Mine has started moving forward a 1/2 inch every time I use it. I am going to turn off the easy out (does very little fir me anyways) and see if that stops it.
waxian
PA
My workaround for this is to use the 3rd memory button sort of as a rest. I have it set with the seat the entire way back and the steering wheel up as far as it will go. If my wife was driving the car before me (memory button 2), I hit the 3, get in, start the car, and hit my actual memory button 1. It always ends up in the right spot when I do it that way.
W
wb0hhm
I had my 2021 platinum worked on a few months ago they changed out the seat memory module
it is much better now , It was really acting up before taking it in for service, moving by itself just
opening door it would move ahead, push the driver right up to dash etc.
but after part replace it still needs adjustment back at times , going to try the trick mentioned above
thanks Ray
