Downpipe install cost
Detroit, MI, USA
Since I don’t have a lift and no one can give a straight answer on how to approach this; I’m planning on taking my Explorer in to get the fenfab downpipes installed on the ST. I’m curious what others paid and how long the job took to get done?
Nbk4t5e
San Antonio, TX, USA
4 to 5 hours of what ever the labor cost is.
Chrisicle
Detroit, MI, USA
Any tips I can give to the shop? Maybe make there lives easier and save me a few dollars?
Toronto, ON, Canada
I had the SPD dp's put in by Ford and it took them 4hrs @ 150 per hour!
Chrisicle
Detroit, MI, USA
Oh my god, luckily this shops rate is half that so hopefully they can get it done in a similar amount of time
Nbk4t5e
I believe the passenger side is straight forward but A lot of ppl mentioned having to drop the transmission some to get the drivers side in …. Or vise versa
Jwbreeding
Active Duty U.S. Air Force
Charleston, SC, USA
I peeked under the explorer the other day in prep for my downpipes being ordered. I will tackle them myself but I looked at the driver side because I thought I remembered reading the passenger was the tougher one and the driver side looks rough. It's a tight work area but I will get it. That makes me feel better though about the passenger being straight forward.
Nbk4t5e
I dont remember if it is passenger or drivers . I just know one or the other is a pain.
It’s the passenger side that sucks. Drop the subframe a couple of inches for clearance and it’s a lot easier. Driver side is super easy.
Could you not make a few progressive cuts with a torch (avoiding any damage to the O2 connections) in order to remove sections of the passenger side downpipe/insulation until you have easier access to the two nuts for removal of the OEM passenger downpipe?? Haven't looked yet but just wondering. Can I assume access to the nuts on the Fenfab downpipes would be easier than working with the OEM downpipes??
It’s the heat shielding that’s in the way and it’s welded to the DP up by the flange.
Jwbreeding
Charleston, SC, USA
Damn, well I'm still going to tackle this job. Thanks for the tip with the subframe.
Sleepy Hollow, NY, USA
Had it done today, Downpipes and Midpipes replaced. Shop took 5.5 hours. They said it was a real bitch.
Norvgen
Sun City West, AZ, USA
2020 EXPLORER ST
$230.00 at my dealer.
Bear, DE, USA
I just ordered SPD Downpipes, do I need to order replacement gaskets or anything for the install? Just want to be sure I have everything I need and no surprises when I install.
SHOinVa
U.S. Coast Guard Veteran
Portsmouth Va
Lol, that’s the hourly rate where I’m from.
I wonder what he means by "dealer" most dealerships I know won't even let you pull into the shop for $230.00 much less do any work.
