Remove "Explorer" from rear of 2025 ST
Houston, TX
I'm considering removing the explorer lettering from the hood and from the rear liftgate of my 2025 ST. I've found threads about removing the hood letters but cannot find anything on the rear letters. Just trying to confirm there's nothing but adhesive holding them on and if anyone else has done this. Thanks for any help.
Yep, the rear “ST” emblem is just held on my adhesive.
Massachusetts
2023 ST
Are you referring to the explorer lettering between the taillights?
I believe that is part of the trim, but I am not 100% sure. Curious myself now.
Those are just adhesive too.
S
Houston, TX
Yes, that's correct, the explorer letters between the taillights. I've found some facebook threads of people saying they come off easy and at least one guy that said he damaged the taillight bar doing it and that it's not worth the risk. Google AI says they are held on by adhesive only. Just looking for any experience people have had to see if it's worth the risk. I generally despise those letters on the front and the back, not because they look bad, but because cleaning around them is a hassle and never really gets done right without more attention to detail than I'm willing to put into a regular wash and dry.
The guy who messed up used the wrong adhesive remover. You need to make sure to use automotive goo goo gone.
I didn't even know there was an automotive goo gone and that adhesive is so stuck on the plastic, I'm not sure it would work! Let me just warn you... don't do it! Not worth it! I'm waiting until it gets warm to fix the damage to that taillight from goo gone and rubbing.... easily damaged!
Combatvet
The black plastic is extremely sensitive to solvents and scratches. Anything you remove will have to be polished and there is not guarantee that the adhesive remover used won't discolor it. Proceed with caution, I advise not to though.
S
Houston, TX
Thanks guys. I'll leave the back alone. I'll probably go ahead and do the front though...
Combatvet
Be careful when using adhesive remover on the front as well, alcohol is ok, but anything more caustic might discolor the grill area. I know this because I damaged a small area around where I removed the front emblem.
I’ll tell you, some of y’all really overthink some very simple stuff. Pop the rear emblems off with fishing line or whatever you like, get rid of the adhesive with goo gone then polish back out any scratches you may have caused in the process. The whole project shouldn’t take more than an hour.
Plain old mineral spirits work very well also and it won't hurt anything.
Mobile, Alabama
2025 Explorer ST 4WD
Yep, used fishing line more than once, and goo gone stays in my garage. That being said, I like the "Explorer" on the front of the 2025.
Lubbock texas
2021 ST carbonized grey metallic w/black leather
that is what I did. spray goof off let sit spray again 5lb fishing line sawed right through took 10 min.....
NYC
2026 ST
So, I removed the rear letters and decided to use a rubber wheel to remove the adhesive (bad idea). It looks like I might of burned the plastic bar a little. Would a plastic polishing compound work to remove the damage or am I screwed?
We told you not to try! That said what i would do is use plastic polish and get the surface smooth again. Then wrap the whole bar in lens vinyl wrap. I personally like dark tint so i do not see the red lights except when they are on.
NYC
2026 ST
I know, I know, but it was very tempting. I ordered a 3” polisher and plastic polisher/restorer. Going to try to hit the burned marks and see if I can get them back to almost new this weekend.
St. Louis
Any more heat on it, is probably not a good thing. Which is what a polisher is going to introduce to the surface.
You received some solid advice, I would follow it before more damage could occur.
No shade, all love.
EDWYER
You may do more harm then good.
Minnesota
2026 ST
A quality polisher, soft pad (yellow) and some good compound and it will be like new. There is no risk in polishing the black plastic as long as you have minor skills. A quick one-step polish is the quickest way to clean up these ridiculously soft black plastic trim pieces. One the doors, the back hatch, the grill, etc.
