Did the horsepower change on the 3.0L
#41
Might be 385hp on 87 octane and 400hp on 92 premium gas.
Ford never states their engines on 87, premium only.
Massachusetts
2023 ST
#43
the little footnote next to the 385HP number says it was achieved using premium fuel
acidmoder
United States
#44
From Gemini:
You’re spot on. That 385 hp figure isn't a typo or a different trim—it’s actually a very recent mid-year production change for the 2026 model.
While your **2025 Ford Explorer ST** is rated at the familiar **400 hp**, Ford has officially revised the output for the 2026 model year depending on when the vehicle was manufactured.
### 2025 vs. 2026 Horsepower Breakdown
The performance specs for the 3.0L EcoBoost V6 now depend on the vehicle's build date:
| Model Year / Build Date | Horsepower | Torque |
| **2025 Model (All)** | **400 hp** @ 5,500 RPM | 415 lb-ft @ 3,500 RPM |
| **2026 (Built before April 13, 2026)** | **400 hp** @ 5,500 RPM | 415 lb-ft @ 3,500 RPM |
| **2026 (Built on/after April 13, 2026)** | **385 hp** @ 5,500 RPM | 415 lb-ft @ 3,500 RPM |
### Why the Change?
This 15 hp drop is primarily due to updated emissions hardware. To comply with tightening EPA and CARB standards (which are moving toward 2027 requirements), Ford has begun integrating **Gasoline Particulate Filters (GPF)** into their EcoBoost engines.
Similar changes were recently seen in the 2026 F-150's 3.5L EcoBoost engine. These filters help reduce soot emissions but create slightly more exhaust backpressure, which often requires a software recalibration that results in a lower peak horsepower rating.
### Key Takeaways for ST Owners:
* **Torque is Unchanged:** The 415 lb-ft of torque remains the same across all versions. Since torque is what you "feel" during low-end acceleration and towing, the real-world driving experience shouldn't feel significantly different.
* **Affects Multiple Trims:** This change isn't exclusive to the ST; it also applies to the **Platinum** and the new **Tremor** trim when equipped with the 3.0L V6.
* **Fuel Requirement:** These ratings are still typically achieved using **Premium Fuel**. Using regular gas will likely result in a further reduction in performance as the ECU pulls timing to prevent knock.
#45
Gosh I hate AI. Anyway, it’s just pulling what we’re posting which is speculation, there’s been nothing official on the subject from ford. Also, this doesn’t apply to the platinum, which doesn’t come with the 3.0l anymore.
Edubdiz
Glenville
#47
I think it is pretty wild that we do not have an answer yet?!?!? Seems like a pretty straight forward question.
Catmonkey
Louisiana
#48
i have a Feb 26 build date, not that I won't throw all the usual bolts-ons and a tune at some point. As to the torque spec, those peak numbers are generated at much lower rpm than peak power, so I wouldn't expect them to change.
#49
Well, the AI response gives a date of April 13th, so we'll know soon enough
#50
My 2026 build date is 3/23/2026. No GPF.
Gulf Breeze, FL
26 Explorer ST, 21 Bronco, 24 Ranger Raptor
#51
We have an early 2026 model... purchased in December 25. No GPF on ours.
Catmonkey
Louisiana
#52
From Ford Authority:
As confirmed by Ford, starting with mid-2026 production, the 2026 Ford Explorer featuring the 3.0L EcoBoost lost 15 horsepower. For the 2027 model year, the Explorer will only receive the reduced power output in states that follow the California Air Resources Board emissions standard. This is due to the adoption of a new gas particulate filter, which drops 3.0L EcoBoost V6 output to 385 horsepower, although torque remains the same at 415 pound-feet.
As such, buyers of the 2026 and 2027 Ford Explorer 3.0L EcoBoost in California, Colorado, Connecticut, Delaware, DC, Maine, Maryland, Massachusetts, Minnesota, Nevada, New Jersey, New York, Oregon, Pennsylvania, Rhode Island, Vermont, Virginia, and Washington get the reduced-horsepower version. All other states get the regular 400-horspower output version of that engine.
https://fordauthority.com/2026/06/2026-2027-ford-explorer-ecoboost-v6-drops-15-horsepower/
Gadgtfreek
Mobile, Alabama
2025 Explorer ST 4WD
#53
So freaking dumb. Do your research on the used car market lol.
Virginia
2026 ST
#54
Dumb move by Ford to not bump up power to compensate, especially with Dodge rolling out the R/T with the 475hp engine.
Farmers Branch, TX
Dumb move by Ford, especially with Dodge rolling out the R/T with the 475hp engine.
Dumb or not, unfortunately it's required. The 6.4L Hemi is not relevant, since it's not turbo charged.
Do you think they just did it for the fun of it? They have to meet new emission standards and this is how it’s done. Dumb would be to not do it and lose the certifications for the EcoBoost engines.
Massachusetts
2023 ST
#57
My speculation is Ford is just pushing this gen Explorer along until the refresh with as little investment as possible. Hence things like the sinister package.
I’m crossing my fingers the next gen ST will have some good improvements in performance. I’ll prob be in the market to replace mine the 2nd model year of the new gen. That or a Cayenne
Gadgtfreek
Mobile, Alabama
#58
I’m crossing my fingers that the next-gen ST will have some good improvements in performance. I’ll prob be in the market to replace mine the 2nd model year of the new gen. That or a Cayenne
I'm with you there. There are a lot of great options in that market, and I love my wifes Porsche. Guess what, in the Porsche you turn off auto start stop, and it stays off until you push the button again... Don't have to buy a part to turn off a forced feature.
As far as Dodge goes, I'll never buy one, so I'm not really worried about their new line of crap. My plan was to ride this 4-5 years, which would be around 50k miles, and then see what's out there.
Virginia
2026 ST
#59
I meant dumb in the fact of not bumping the power up a bit to Compensate for the decreased power. I doubt it’s tapped out completely for 87 grade.
As others said, any drastic changes will probably wait for the refresh which is understandable.
Gadgtfreek
Mobile, Alabama
#60
Let's be honest, the power can be bumped up pretty easily. ZFG says hi.
