windshield replacement - go with Ford? or aftermarket?
Ashburn, VA
Yeah, the de-icer was standard on the ST in 2020, then ford started their typical de-contenting and it disappeared in 21 and not only did they remove the heating element but they removed the entire harness that it plugged into.
The de-contenting' started mid 2020 as my 2020 does not have the windshield deicer, my friend's 2020 does. The games car manufacturers play - get the options boxes checked at new model launch, then slowly decontent or make as options...
My 2020 has the de-icer windshield
Missouri
21 Explorer ST
I have to have the windshield replaced on my 21 ST. When you guys had yours replaced, did the oem replacement have the tinted strip at the top? All the ST's I've seen have this. Is this oem or a dealer add on? I really like having this so I want to make sure it's on the replacement
Toadster
Toadster
Folsom, CA
Thread Starter #24
no tint on my OEM replacement, it does have the explorer image on the passenger side though...
will need to put a new tint strip on
Honolulu, HI, USA
The windshields have to be calibrated for the various sensors in the overhead panel. Safelite did a quick correct replacement for me and did the calibration test drive in about an hour with appointment.
EDWYER
#26
Always OEM.
Suprawill1
Where is the switch to activate it? I'm thinking mine doesn't because it was actually built in '19.
There is no switch they come on when you turn on your defrosters. Look at the bottom of your windshield you will see the heater strips like you have on your rear window.
ARC
Oak Lawn, IL, USA
2022 ST Black
#29
I have to replace mine as well.
OEM is 750.00 installed
or aftermarket who I am told by the same manufacturer is 550.00'
The only difference would be the small explorer image on the lower part of the window.
#30
The heated wipers were removed after the first or second year along with a slew of other features I like like front camera washer, etc.
#31
Only the 20's got the heated windshield. My 21 did not come with it. If you would like to have that feature, pay the extra for the OEM glass, and tell them you have a 20 with the heated windshield so you will get the correct one. Ford also removed the wiring for the heated windshield so you will have to run your own circuit, but it can be done.
After 2020.
Jeppo
Davidson County, NC
#33
$750 is an exceptional price.
Chicago IL
I have this haze on my windshield and it's making me crazy. I'm pretty sure its the material between the two layers of glass and the only solution is to replace the windshield. Any tips on this? The windshield is also cracked so I'm thinking it might be time to replace it if possible. Are there good windshields and new gaskets readily available? Thanks in advance,
It's most likely buildup on the inside of the windshield. Get a mixture of 50/50 water and isopropyl alcohol 70% for your cleaning solution and a waffle weave MF towel. You might have to do multiple passes to get it clean. Do it for the inside and outside of the windshield, always using a clean side of the towel for final wipe.
I'm on windshield #2 from Safelite, no issues with the second one. Just had it replaced a couple of months ago for a crack in the corner.
Hull, GA, USA
#35
The only thing that fixed my haze was using a magic eraser followed by glass cleaner. It drove me crazy for a while.
Toadster
Toadster
Folsom, CA
Thread Starter #36
I think Explorers are magnetized for rocks or something... going in tomorrow for a 3rd windshield!!
Suprawill1
Just got a Safelite replacement last week. The tech was friendly, informative and efficient. It was replaced at my house in about an hour including recalibration.
Everything is as was. Without insurance, it would have been close to $1100. The deductible was $200.
Atlanta
2026 Ford Explorer ST
#38
Going thought the same thing. safelight Tech just left. As he started setting up he noticed the replacement was not OEM and he called me out to look. He called his manger and the proper windshield is in stock and rescheduled for 2 days from now. Going to be around $1200. Deductible is $1009 so paying out of pocket. Expensive rock on a 2026 st that not even 3 weeks old. Sigh.
Suprawill1
What a b4ll buster that is! Sorry to hear.
Jeppo
Davidson County, NC
#40
Safelite will also quote you on the OEM glass if you ask. I found the service used by local Ford dealers and they were cheaper than Safelite. I paid extra for the Ford glass and am satisfied.
Ask the dealer’s body shop if they’ll put you in touch with the company they use. That saved me a lot.
