Has anyone "tuned" their gauge cluster?
Ldstang50
FL
Has anyone been able to change how their gauges display? The new Mustang has the ability to change the way the gauges display; I want to say some of the options are the old Fox Body display and maybe the display of the 60s car
I personally can't stand the gauges. The temp gauges (water and oil) are just a line, not displaying any actually numbers. The turbos are oil cooled, so knowing the temp the oil is pretty important. Oil pressure is another parameter I feel should be known to the driver
Thoughts?
As far as I know the cluster cannot be changed. I know a lot of people have talked about it.
i have an open case with ford on the IPC
in fact
friday it had an appointment to do an update on ipc
service guy and i rescheduled update until next thursday as the file from ford said allow 7 to 9 hrs to update??? we couldnt figure out what changes
i also spoke to a person at ford engineering for the st about our crappy gauge cluster especially in sport and tow haul
at least tow haul w get a trans temp...
but we should have option for boost and both the eng and trans with numbers like we do in the f150 cluster
its IN THERE already..just needs an update of programming from ford to TURN IT on, so to speak
i have a thread on it here,, feel free to write ford and COMPLAIN . thats the only way it gets fixed
one person cant get it done, it takes a flood of calls and letters
https://www.explorerst.org/threads/sent-this-to-ford-yesterday-about-ipc-cluster.8142/
Thoughts?
It has been talked about a lot. No way to do it unfortunately. Best way to monitor is get on old SCT or get an old phone and scanner.
which is total bullll for car touted as a sport version :eek::eek:
i have a odb mx plus to send data to an old android phone...it works but ugly as two 90 year olds making porn :ROFLMAO:
L
Ldstang50
FL
in fact
good deal man. Thanks for doing this. I’ll write Ford
I’ll be honest, I didn’t search for a similar thread thinking others don't see it as a big enough issue, obviously I was wrong. I’m happy to see numerous others have the same complaint
Canby, OR
You can also get an OBD2 gauge if you have the cash. Here are a couple:
aFe Advanced Gauge Display Monitor
P3 V3
Those things are garbage! One is so tiny and can only display a single parameter at a time and the other is a big old display that creates blind spots. Ford should have given the ST the same options as the F150 from the start.
Bridgewater, New Jersey
in fact
I'm just wondering if you were able to get anywhere with your appt ?? Was the service guy able to download anything and did anything change ???
trubluST
Clear Lake
2025 Explorer
A gauge I would really like on these ST's is a voltmeter. Especially since we had a battery issue on ours.
Minneapolis, MN, USA
Has anyone swapped out speedo cluster for the Lincoln aviator cluster, and if so does it work with all drive modes
New Hampshire
P3 Gauge has a volt meter setting, I currently use trans temp setting on mine. Yeah it only shows one parameter at a time but its clean and looks OEMish haha.
That would be a huge pain to try to get all the electronics to work together, for not much benefit.
Supreme Ruler
EMT
Washington State
I could have sworn that you could change the water and trans temp to numbers via Forscan?
Supreme Ruler
EMT
Washington State
I really think that there is a way to change the temp swing bar, on the water, and trans into a number. I'm looking for the article and link #'s for FORScan. I think it's on the 720-17-01 line. Anyone who's fluent in FORScan?
Im pretty fluent with it, and no changing those values dont give you those results. The reason they are there is because Ford places them there for other vehicles that have the capability to show that stuff.
Supreme Ruler
EMT
Washington State
Well, now doesn't that just stick! Expletives!
