JXB rear differential bushing inserts and carrier bearing support upgrades IN STOCK now @whoosh motorsports
Las Vegas, NV, USA
EDWYER
Insert kit is on my to do list!
Bigal2001
DFW
Do the diff inserts add any NHV?
EDWYER
I wouldn't think so but I'll let you know once installed. @ron@whooshmotorsports any Labor day sale planned?
Las Vegas, NV, USA
I didn't notice any added NVH after adding the JXB to our 2023 ST
the JXB was installed with the cp-e rear diff brace and our diff bolt and pinion bolt upgrades
Las Vegas, NV, USA
yes, we will have our sale posted later today which runs from sat through mon
E. TN
2020 Ex Platinum
Any upcoming sales?
College Park, Maryland
Installed the inserts and did have increased NVH but found it was caused by worn pinion bearing that was not noticeable with the un-reinforced/soft OEM bushings. This is an issue found by several individuals who installed the JXB. Not the fault of JXB! Great product and easy install! Highly recomended.
Charlotte
Where was your worn pinion bearing? I installed the JXB rear insert and Steeda subframe bushing support kit at same time. Now I have increased NVH and a much more noticeable clunking noise between lower gears and stop & go. This clunk existed slightly before but I thought was normal as it’s existed for the entire existence of owning this vehicle when I bought it used at 36,000 miles 3 years ago. I know Explorer’s are known for excessive drivetrain slop.
Do I just need to add the JXB drivetrain carrier support bearing to compensate for the added rigidity of the rear differential and subframe? I’m thinking that would help, BUT I need to know what is involved with inspecting/replacing a worn pinion bearing. Where was the location of yours? The clunk is concerning. Again, the clunk existed before the install, and I’ve had the rear subframe and rear differential bolt and bushing replaced under warranty AND recall. Point being, I don’t think my problem is coming from behind the driveshaft.
(I have the 3 bolt setup btw, I know 4 bolt owners claim to have had increased NVH with the JXB insert. Personally I think the insert isn’t the problem and that the actual problem is being amplified due to the increased rigidity of the rear end)
Bigal2001
DFW
After my JXB insert install I noticed a whine, almost grinding sound on deceleration. I replaced my rear end with a low milage unit and the nose went away immediately. I drained the fluid of the old diff and saw a ton of gold flake. I'm sure the diff was eating the pinion bearing and it wasn't noticeable until the inserts were installed.
I found my rear center section was the culprit by changing the fluid. The magnetic drain plugs were full of sparkle sludge. Not sure what component(s) went bad. I've since replaced the center section with a low milage salvage unit from an aviator and went back to OEM pinion bushings (I read several posts about the Steeda pinion bushings breaking at the flange). The noise has gone away. The next issue is the shop that replaced my center section didn't use the right tool to remove the driveshaft and bent up the driveshaft flange where it meets the pinion. SMH
EDWYER
That's good to hear. May consider the inserts again.
Charlotte
Center section of what?
Charlotte
I’ve never heard of a rear differential referred to in that manner. That’s what you’re saying right? Lol. Learnt something new.
My understanding is the term references the pinion and housing with the gears only and does not include the diff cover, axles or anything outboard. Sometimes referred to as the "third member" too.
EDWYER
@ron@whooshmotorsports any time frame for Versus engine bay pack in blue or red to be back in stock?
EDWYER
