Rear differential brace
Why is the ID Speed brace better? Because it costs more? Because it’s over engineered? I do agree it's very nice but my point is that no one is having diff. or bolt breakage failures (or at least that I have heard of or read) with the use of any of the aftermarket diff. braces. You can argue certain braces prevent certain articulation or twist of the diff., but again, no one is having failures with any type of added brace. I have the AWR on my ST and I tow at times to the very max GVW & GCWR in hilly mountains. Absolutely no issues what so ever. IMO, any diff brace is a good piece of mind upgrade.
Yes it does cost more, no it is not over engineered, it is properly engineered. Two people already have had their diff bolt still snap with AWR. The AWR because it is a one side support, puts more stress on the one bolt then other supports, because it is causing a torsional affect on the rear differential. Sure, for most people it may be adequate, but there is no doubt the ID-Speed is better designed and protects the bolt more adequately.
Why is the ID Speed brace better? Because it costs more? Because its over engineered? I do agree it's very nice but my point is that no one is having diff. or bolt breakage failures (or at least that I have heard of or read) with the use of any of the aftermarket diff. braces. You can argue certain braces prevent certain articulation or twist of the diff., but again, no one is having failures with any type of added brace. I have the AWR on my ST and I tow at times to the very max GVW & GCWR in hilly mountains. Absolutely no issues what so ever. IMO, any diff brace is a good piece of mind upgrade.
The ID Speed and Livernois braces are the only ones on the market that haven’t had a failure, and that includes AWR cracking at the bolt holes and diff bolt breakage even with it installed.
The world record 1/4 mile ST runs ID…hard to put one through harder testing than Kathy has.
Caster
Maybe I'm protected a little more since I have the JXB bushing insert with the AWR brace and an upgraded diff. bolt.. It evens things out more.
Massachusetts
2023 ST
This kind of makes me wonder how many of us with the 3 bolt diffs are driving around with a bent rear bolt lol.
Kind tempted to check mine, but I also don't want witness marks on the bolt in case there is an issue.
I also think if i go through the trouble of removing the bolt to check it, i might as well install a brand new one.
B
Wisconsin
Thread Starter #26
Has anyone heard of a ford dealer installing the upgraded hardened diff bolt? If ford is aware of this potential weak point, it would be cool to have this done at the dealership for warranty purposes. For my driving style, this would suffice.
#27
No it wouldn’t. The upgraded bolt does nothing by itself. Even if you dont launch often, even a little harder driving can just bend it or snap it still.
B
Wisconsin
Thread Starter #28
Yeah I understand. I’m grasping lol
Massachusetts
2023 ST
#29
Agree, the bolt alone isn't the end-all cure for the issue. A class 12.9 is only about ~15% stronger than a 10.9 bolt, but one downside is that it is more brittle. SO while the Ford OE bolt may bend as it approaches failure, the 12.9 bolt will resist this much better, but then just snap when it reaches it's breaking point.
#30
Yeah, the bolt alone isn't the end-all cure for the issue. A class 12.9 is only about ~15% stronger than a 10.9 bolt, but one downside is that it is more brittle. SO while the Ford bolt may bend as it approaches failure, the 12.9 bolt will resist this much better, but then just snap when it reaches it's breaking point.
This is one thing that has me thinking about putting a factory bolt back in. With the addition of a diff brace, I think I might prefer a bolt to bend more before a break.
Has there been anyone who has broken a 12.9 bolt with a brace?
Massachusetts
2023 ST
#31
I think it all depends on which brace one uses. There are many designs now. Some like the steeda brace support both sides, so there would likely be very little torsional force due to asymmetric support. And then there are some of the older "classic" designs that brace on one side and might cause some twist in the diff as it loads up. How much also depends on the durometer of the bushings used compared to the durometer of the factory single bushing. I'm just speculating here as i do not have any real world data to base anything off.
But it's a good question. Tried to comb through the FB groups to see if anyone snapped a bolt with a brace, but everything i found was all hearsay type posts where someone's mother's father's cousin broke a upgraded class 12.9 bolt while idling in the school drop off line.
Caster
The only people putting a factory bolt back in is a dealer. Pretty much everyone who changes the bolt goes up to the 12.9 metric bolt.
#33
I have not seen someone break the upgraded bolt with a good brace.
561
#34
I wouldn’t get the AWR brace, ID-Speed/CPE is worlds better.
The AWR brace is a ridiculous waste of time and money. I just got through fighting with Lethal Performance to take this brace back. They FINALLY agreed. You can not get the top right bolt into and through the brace and into the differential without cutting the bolt about a half an inch.
The brace is advertised as a no modification install, but that is total BS run from this brace. Of course there are folks that will spend over an hour under their car to play with, move, tip, rock, and eventually get that bolt in - however, THEY WILL NEVER GET IT OUT. If the brace needs to come off and you got that bolt in without cutting it - I doubt you will get it out again.
I don't want to pay $300 for an important mod that they falsely advertise and which is not properly engineered. I am also, pretty PISSED at Lethal Performance for F'ing me over on the return and also making me pay the shipping $38.50 to send this POS back to AWR. I will THINK TWICE about buying anything more from them.
Caster
What an ignorant post. I don't think you will get much sympathy on this and you shouldn't.
Maybe this will help when you have something of real substance to talk about.
561
#36
Truth hurts... you must own a AWR brace or are a Lethal Fan Boy best of luck with that :ROFLMAO::ROFLMAO::ROFLMAO:
#37
There’s literally hundreds of people running the AWR brace and perfectly happy with it. Just because I didn’t care for the design of it, doesn’t mean it’s a horrible product, it’s just not the best one. It takes time to install stuff and get it to fit right, it’s not going to be a 10 minute job. A hour to install a diff brace is a good time.
561
#38
[quote from 2020FordRaptor: - "Two people already have had their diff bolt still snap with AWR. The AWR because it is a one side support, puts more stress on the one bolt then other supports, because it is causing a torsional affect on the rear differential" ]
Yup- protecting one side of the Diff while the other twists and torques to its hearts content, a perfectly designed product - I think not...!!!
#39
And I acknowledge I should’ve been more specific on that, I don’t like the design of it cause those that actually run there cars really hard still have a chance to snap that bolt, but for those that just need something cheap to do the job it’s adequate. Again, not my favorite nor anything near the best, but it’s not horrific.
Minneapolis
#40
The hardest part is getting to the top right E18 bolt. You will have to install the bolt into the brace first then use the indention in the subframe as a relief to get the bolt straight enough to get into the diff. I used a E18 wrench. You will need to rotate the wrench all the way up toward the body to get rotation then use a small area lower to get a small additional rotation in order to re-attach.
If you are adding a stronger diff bolt (recommended) support the diff with a jack (adjust as needed) so you can get the alignment straight to make installing the new bolt easier.
@SugarMouth I am in the middle of installing the ID Speed brace, the instructions are a bit vague on some details. It says to remove 4 diff cover bolts, and I can see which 4 they mean, including the one that is up on the right that is hard to get to. But then it says to re-use one of the factory bolts and use the other 3 supplied new bolts. It does not say WHERE to put the three new ones or if it matters. Any thoughts? From your pic I can tell obviously where you put 2 of the new ones...I would guess that I'd put the 3rd new one way up top on the right. Anyways...help? Thanks
