2020 Seat Cover Upgrade to 2025
Ford2581
San Francisco
I just picked up a 2020 and a week later the drivers seat ripped, of course I discovered this was common. While looking for a new seat cover I scored some take off 2025 covers for next to nothing. I was sorta rolling the dice because the 2020 seats are different from the 21+. They do fit, while I was changing the covers I also fixed the broken wires to the lower seat heater temp sensor which was broken on both seats causing the heaters to be inop. The lower foam is a bit different, when the seat heater fails again I'll be changing the lower foams out on both seats. I'll likely be swapping out the door panels and console lid at some point but I'll give the kids some time to mess up the originals first.
Left Original.jpg Drivers Rip.jpg Seat Frame Front.jpg Seat Frame Rear.jpg Seat Heater Broken Temp Wires.jpg Left Finished.jpg Right Finished.jpg
EDWYER
Nice.
Farmers Branch, TX
How's it feel driving? Do you feel more planted in the seat?
I had a Pontiac G8 GT with what everyone joked was kangaroo leather seats, and I always felt like I was sliding around in the seat through turns.
Then I had a 392 Charger with Alcantara seats and I felt like I was glued to the seat through turns by comparison.
Now again, with the ST, I feel like I'm sliding around through turns, and I'm wondering if the leather texture makes that much of a difference.
New Jersey
View attachment 33315 View attachment 33316 View attachment 33317 View attachment 33320 View attachment 33321 View attachment 33318 View attachment 33319
How long did it take you?
Ford2581
Ford2581
San Francisco
I'm very planted in the seat now, no sliding and the seat feels overall more solid (not that it is). My Edge also has Alcantara inserts and it stops all the sliding vs regular leather.
First one took a couple hours but that was also due to running tests to determine why the seat heaters weren't working, the second one was a little over an hour.
EDWYER
I do like the Alcantara inserts.
Katzkin take offs?
OEM 2025 Take offs
I meant OEM takes off when Katzkin does seat cover installs. Katzkin keeps the covers and was wondering if you got from them or an installer for them.
Ford2581
Ford2581
San Francisco
Ahh maybe, seems sort of odd to swap out these seat covers but people like to customize their rides.
EDWYER
Not odd at all especially if you have have a lot of miles the seats get worn.
Austin, TX
2022 with all the goodies.
So I'm assuming the 20
So if they fit your 2020 base foam well enough, they should fit pretty well on 2022 seats? Cause if so I'll definitely buy these covers and put them on mine!
Ford2581
Ford2581
San Francisco
I don't see why they wouldn't fit the 2022's, the lower seat foam from the 2020 fit well with the 25 covers. The lower seems to be the same from 20-24. Just keep in mind the stitching is red vs silver.
