Wallingford Conn area
CT-planB
Wallingford
2025 white ford explorer st
Hey All,
New to area and looking for some ford guys to do a few items.
Installing springs
Wheel spacers
Wrap
Wheel spacers are easy, if you can change a tire, you can do wheel spacers. Just make sure you get hub centric spacers so the load is on the hub itself and not the lugs. The 20+ explorers use a 5 x 4.5" or 114.3 mm bolt pattern with 14mm wheel studs and a 70.5 mm hub bore. BTW all mustangs from 1994 to present use the same and the early explorers up to 2010 did too. The 11-19 explorers had a smaller 63.4mm hub because they were fwd based platform. The only difference is the mustangs used a 1/2-20 wheel stud up to 2014, and the explorers up to 2019.
Hey All,
Installing springs
Wheel spacers
Wrap
Any competent shop near you should be able to easily do that stuff. Calling around and getting quotes and looking at reviews is the best thing to do.
Wallingford, CT
Hey All,
Installing springs
Wheel spacers
Wrap
Truck Toyz Rocky Hill CT is the go to
C
Wallingford
Ok thank you
