295/40r20, Anyone running this size
North carolina
2023 explorer st
I got a 2023 Explorer ST. Looking at playing with the tire size. This size has lots of options for descent tires. I know i will need to recalibrate my speedo. Curious if anyone is running this setup and has pictures ?
I would not recommend 295 on the stock OEM 20's.
R
North carolina
2023 explorer st
Curious why.. Also. this is on a 2023 Explorer ST which comes with a 21x9 OEM wheel
Might want to change your title.
Which tire make and model? I'm not saying you couldn't get away with that wheel width, you can, but another inch in wheel width would probably be closer to the tread laying flat ideal. That doesn't take into consideration the possibility of rubbing.
R
North carolina
2023 explorer st
thinking about this setup
michelin tires pilot SUV
20x10.5 +30 ( i think +30 makes it flush ?? )
295/40r20
295/40r20
Yes, that’s the golden setup for these vehicles. A 295/40r20 is too short though, would look a bit wonky. 295/45 is what you’d want.
R
North carolina
2023 explorer st
thanks
Looking for pictures if anyone has this setup too..
Plantation, FL
Sorry guys still kinda new, would you guys think these wheels would be able to do the same size yall talking about?
No, the stock wheels are only 8.5” wide, so the widest tires you could run would be a 275/50r20.
