ABS problem
Hamza
Firefighter
Iraq
Explorer ST
I have a Ford Explorer ST model 2022 with a brake system malfunction. I bought several ABS units from eBay, but they all received the same error code, C0049:01, and also displayed error U0418. The number of accidents involving these units was relatively small. I tried several methods to fix these errors, but to no avail. I even drained the brake fluid using software, but the result was the same. Does anyone have any information to help?
EDWYER
Parts from Ebay may the problem.
H
Hamza
Firefighter
Iraq
Explorer ST
Probably not ABS module problem. Did you replace anything else? That first code is low brake fluid--maybe the sensor is faulty. The 2nd? maybe check all your ABS sensors at the wheels.
