Whine / Harmonic Resonance in driveline
butt_yodel
Iowa
Hi guys,
I have a harmonic noise in my rear diff area that the dealer can't find. We have replaced the diff twice, and the driveshaft once. Gonna kind of ramble here, don't know what's relevant, but y'all are pretty smart on here.
  • It sounds very similar to this: Hellcat rear end whine. It is a terrible noise with a pitch that the radio and a thermal 3" exhaust can't cover. Multiple passengers are reporting it's coming from the rear diff area.
  • Barely noticeable hum 30-40 mph. Loud at 58-63
  • Noise disappeared entirely in the winter. Came back in the spring.
  • Transmission gear does not affect noise.
  • Turning does not affect noise.
  • Load does not affect noise.
  • Louder on decel, but present on light throttle in the listed speed ranges.
  • Sound seems to go away if I put the vehicle in Neutral and coast down through the 63-55.
  • This was not present when the vehicle was brand new.
I first noticed it at 3500 miles immediately (driving off the lot) after having downpipes and a diff brace installed. At this point, the car only had Eibach lowering springs, Fenfab charge pipe and turbosmart blowoff valve. The springs produced no issues for 2+ weeks before having the downpipes put in. I've been troubleshooting this the last 15k miles as a brace issue, but recently switched from AWR to ID Speed (improved bushing design) and found that the sound is present with the new brace AND with the brace removed entirely. The brace definitely makes the sound louder, but is not the cause. I drive a '23 ST now, but did not experience these issues on my '22 with very similar mods.
I've had a couple shops look at it to no avail. Ford just keeps replacing the diff as metal is present. The first driveshaft would not come out because the splines were twisted, and they had to destroy it to remove it. Got to thinking about the shop who did my downpipes, and remembered I sent them an install guide that suggests loosening the front subframe and possibly the transmission mount. I got under the car and checked the front subframe bolts, they all seem tight but the subframe is shifted to one side by a tiny amount, probably under 1/8-inch. The transmission seems OK.
The other thing that got me to check the subframe alignment is that I am getting what feels like driveline binding/mild vibration in the 30-40 mph range after installing a JXB driveshaft carrier. I'm totally OK with some vibration for the upgrade if this is expected, just wanted to include it as a data point.
Not sure where to go from here, open to suggestions. I'm having some pretty smart dudes look at it here in a few weeks, anything I should ask them to check? I'm very suspicious of the front subframe/diff area but do not have any drivability or alignment problems -- Just an annoying noise.
Thanks for reading
Desert South West
Have you checked your rear wheel bearings? I had the very same problem with a 2004 Explorer XLT 4x4, I was ready to have the rear diff replaced or rebuilt when I decided to check the rear Wheel bearings and found that the passenger side was in very bad shape, replaced it and the noise at highway speeds went away.
butt_yodel
butt_yodel
Iowa
They seemed OK, I will check again. No noise when switching to neutral, no change in pitch when turning, so I had ruled them out.
Desert South West
You may want to check the wheels unloaded.
AI Overview
To check if a rear wheel bearing is bad, you can perform a few tests while the car is jacked up and the wheels are off the ground. First, grab the wheel at the 3 and 9 o'clock positions and try to rock it side-to-side, then repeat this test at the 12 and 6 o'clock positions. If you feel any play or looseness in the wheel, it could indicate a bad bearing. Additionally, you can spin the wheel by hand and listen for any grinding, humming, or clicking noises, which are all signs of a worn bearing.
'22 ST
Did you ever figure out what the problem was?
Lubbock texas
2021 st
just putting this out there. drive shaft carrier support?
butt_yodel
butt_yodel
Iowa
I switched to a JXB carrier bearing and no change
butt_yodel
butt_yodel
Iowa
not yet. developed an axle click in the past few weeks, getting the rear driver axle and wheel hub replaced soon. probably completely unrelated. gonna throw some thicker fluid and/or friction modifier in soon
butt_yodel
butt_yodel
Iowa
Orwigsburg, PA
If they're making you pay for the axle, hub and labor time, it would be a lot cheaper to have them grease the splines.
butt_yodel
butt_yodel
Iowa
fortunately,
it is being looked at under warranty. otherwise I would definitely be pulling it myself
EDWYER
@butt_yodel Any update?
butt_yodel
butt_yodel
Iowa
Traded for an X3 M40i.
If I had to guess... the only difference between my 2022 Explorer and 2023 Explorer was the 22 had H&R springs and the 23 had Eibachs. The Eibachs are a tad lower so maybe it affected the suspension geometry more. This is a rare complaint, and nobody has figured it out. Usually this is fixed when swapping the rear diff but as described above this was not my problem.
