Clunk in front end
Melbourne, Florida
2025 explorer ST, 2500 miles. started hearing clunking in front end at slow speed about 2000 miles ago, took it in last Thursday, they checked out and said it was a bad bearing on the strut. said they didn't have parts It now been a week and no
word from them. I just tried contacting the service rep. and it keep hanging up, it's going to force me to have to drive to the dealer. I've not hit any bumps or anything in the road that should have caused this. the car had 50 miles on it when I bought it.
Just got a call back from service rep. said waiting on two more parts. they are going to replace the strut and all the parts related to it. I asked if they had any idea how this happened, he said won't really know until they take apart but believes it is probably
just defective part or parts. he's checking to see when I can get it back it to fix.
Has anyone else had anything like this happen to there car.
File it under “shit happens”. Strut bearings go bad..sometimes they’re built bad. Sounds like your dealer is on it and it doesn’t hurt anything for you to drive it.
The midwest
Had them replaced on my ‘20 just recently at around 50,000. It was no big deal: just had to put up with the annoying clunk briefly, but my dealership got in the new ones pretty quick. Other than the cracked CV boots, this was the only warranty work I’ve needed since new.
T
Melbourne, Florida
Thanks for your quick replies. I was a little upset until I got the call from him and that they are going to replace all the parts.
Both of my STs, the old A-Build 2020 and my current 2022, have that odd clunking at low speeds. Even the 2024 XLT rental car I had was doing it. Seems like a common problem.
Welcome to the forum.
23 Explorer ST
My 2023 has been at the dealership for the past 7 days for the strut replacements.
Dealership said all the parts are in and that’s why it was scheduled last week.
According to Ford pass, my Explorer hasn’t been started or moved all this time and is still sitting in the back lot.
Service writer keeps giving me the run around excuses.
I’m going there in the morning to get to the bottom of this hold up.
T
Melbourne, Florida
Got my explorer ST repaired yesterday. They replaced the shock, strut plate and bearing cap and some fasteners. Noise is gone and drives perfect.
JAX, FL
25 Explorer ST & 21 F150 PB
Nice! Mine is still waiting for parts.
21 ST
mine has also developed the low speed clunk over bumps, going in Wednesday for the PIU struts...yuhuuu
23 Explorer ST
Have them check your sway bar end links.
I had my struts replaced the first time and the clunking came back in less than a day.
Second time it turned out the end links had very slight play causing the clunking.
Since then it’s been perfect.
21 ST
i might just have them replace them while they are in there, they claim the links are tight tight, but given the nature of these things it might be good idea to replace them.
23 Explorer ST
That’s what they told me the first time also but during the second time an actual experienced tech looked at the issue and said it’s definitely the end links after putting a stethoscope on it and had another person bounce the front end up and down.
DadFordbidit
Eastern Shore
24 ST
I’ve had the front struts changed out a few times by the dealership and the clunk goes away for a week or so and then returns each time. My service adviser told me to call Ford customer service and open a case. I did that and Ford engineering team has determined the clunk is normal as of now. They claim there will need to be more cases opened for the same issue before anything will be done to correct it. So far, there are only 2 of us complaining of this Issue at this dealership. More folks should call the Ford customer service number (800-392-3673) and open a case. My dealership’s GM is trying to get Ford to do more for this and has even asked them to cover a large incentive to allow frustrated customers with these clunking models to trade out of them.
23 Explorer ST
It’s your sway bar end links. Same issue you have, replaced struts and clunk comes back.
They found the issue with the end links.
No problem since they replaced them.
21 ST
its now been a few weeks since i had the PIU struts and new end links put on, no more clunk!!
