Fog lights and Forscan
Brackneyc
IL
2025 explorer st
2025 Explorer ST.
Quick question. I was attempting to amber light Forscan change, and it wasn’t going well, so I changed everything back to where it was.
I now have no fog lights, and I don’t think I changed anything related to them.
I took a picture of the settings before I changed anything.
i simply changed them back, and cycled it, and no fog lights.
To be honest, I didn’t check them before, but since my explorer only has 857 miles on it, I’m assuming they worked before.
B
Brackneyc
IL
2025 explorer st
Did you save your as built file before making changes?
Yes. I can say that I’m not 100% sure how to reload the original.
I also did try the “last position” modification for the headlight switch. It did not work, and will not let me change it back to the original setting. The last digit was a 4, and it keeps romancing it with a 3.
Line #726-74-01 used to read 0000-0001-00A3. Now the system is changing it to a 3, after it gives me an wrror message about the number being incorrect.
Farmers Branch, TX
The Load All button next to the Save All button. After you select the file and load it, you have to Write All and go through the ignition on-to-off-to-on again like normal.
B
Brackneyc
IL
2025 explorer st
Well, I was able to put everything back to normal. Still no fog lights, but at least I know it’s in the factory settings.
