Front Skid Plate
KegsBdry
KegsBdry
WashDC
Thread Starter #21
Yes the are heavy duty but now you will not have to worry about having the oil pan ever getting damaged from road debris.
Send pics when you get it on. Looks like a good deal for protecting your critical parts.
BozAngeles, MT
It arrived today. Dang the box weighs a ton. Now I’m a bit concerned about the added weight. Oh well, it’s still going on and hopefully won’t have a noticeable MPG penalty during normal day to day driving.
Is there a shipping weight on the box?? I can't find how much these things weigh, but would really like the protection... Thanks!
Arizona
I will look, but at least it was free shipping. ;-)
Arizona
Box says DWT 43.2 (which I assume means dimensional weight).
Columbus, MT, USA
Snap some photos along the way of the plate and install if it's not too much trouble
Arizona
If I was installing myself I absolutely would, but I have a number of items including an intercooler so unfortunately I’ll have the shop install along with the other parts. The instructions are available online. If you cannot find them I am happy to post them here for you if that would be helpful.
BozAngeles, MT
Thanks, that seems reasonable for 2 pieces, let's see that bad boy when it's installed!
King7878
Red deer, AB
2023 explorer ST
We need installed pictures.
Somalia
#29
I've been trying to decide between the Setina plate or the factory Interceptor plate.
I suspect the factory plate may be the Setina plate
King7878
Red deer, AB
2023 explorer ST
#30
I'd tend to believe your correct since Setina is a police vehicle outfitter. The crown vic was much the same for components
Kuwait
#31
Long time lurker since I bought my 22 ST in September.
My engine and transmission oil pan are unprotected, some parts are missing ( maybe different car specs for different countries), a member mentioned website selling Setina skid plates so I took a gamble and bought one.It finally arrived.
I looked underneath my car, I found out:
The transmission crossmember holes don’t have threads, my crossmember part number is L1M3-5060-A. Dealership parts department says it’s the right part for my car.
I tapped the crossmember with a size M10 ( oem bolt size showing in the system), found the crossmember to be made of aluminum.
Setina provides 2xM12 bolts, now I’m thinking, should I go 2 sizes bigger to fit the Setina provided bolts or should I stay with a size M10.
I’m worried about the crossmember holes ability to hold the heavy skid plate and their integrity if I hit something.
I’m thinking of using thread inserts (Heli-coil) to reinforce the holes but I don’t know if the whole area will crack with time.
I hope my findings help you guys and I’ll be sure to update if something new comes up.
King7878
Red deer, AB
2023 explorer ST
#32
I'd suggest running the 10m setup you already Tapped for. Check it at 250, then 500 miles to see if any issue arises. If it's not to promising bump up to the 12m size. Blue thread lock the piss out of everything. If the 12m is still not great have rivet thread inserts put in brace.
Kuwait
#33
An update
Found out the skid plate came with 2 installation instructions stapled together, one for the 3.0 ecoboost and the other for the 3.3 hybrid. My ST undercarriage looked exactly like the 3.3L so I used the hybrid instructions.
Re-tapped the transmission crossmember to M12 ( had 12mm x 1.75 tap I used and found M12 x 1.75 bolts which I used), took 3 hours to get the job done.
Now my ST has a proper skid plate protecting my engine and transmission plasticky oil pans, im going to start monitoring the car temp level to see if the skid plate traps heat ( it’s already 122F where I live).
Charlotte
#34
An update
So what’s the verdict? Did it trap a significant amount of heat? Did you take readings before installation? I’m wanting to install the skid plate but my only worry is if it’s a heat trap. I push my car hard enough as it is.
Chicago
Ford Explorer ST
#35
The HSF versions would likely be better for venting heat. Also would assume they are much lighter:
https://houstonspeedfreaks.com/products/hsf-2020-2025-explorer-st-under-tray
https://houstonspeedfreaks.com/products/hsf-2020-2025-explorer-st-transmission-under-tray
Charlotte
#36
Thanks, but I’m already aware of their existence, and significant cost over Ford’s oem plate. Not sure of the weight savings between the two (not including the carbon fiber one). This is why I’m trying decide on the Ford skid plate, if it doesn’t trap enough heat to make any difference then I’m just going to get it instead of HSFs. Plus I’m not a huge fan of logos being so visible. Even if it is a skid plate, I don’t need people who see the underside of my car looking at ”HSF” while they’re down there. (No offense to him but I’m just like that with any logo, I do follow him and use some of his products though).
I also appreciate the steel vs aluminum. It will be much stronger and will help lower the center of gravity even more. If I wanted to go the extra mile I could get slits cut into Ford’s skid plate to prevent heat buildup. But I’m wanting to know if it’s a heat trap or not to begin with. I’d rather just spend a couple hundred bucks and have a stronger product if I can.
Chicago
Ford Explorer ST
#37
Gotcha, it's the better choice purely for performance, but the Ford plate should be able to take a beating.
Kuwait
#38
I would say it's within the normal operating temperature of the engine and transmission. I saw a bit of an increase while parked or a traffic light stop ( ranges from 174F moving to 195 F parked). I logged the temps with forscan during 60 mile drive to work. Before the plates the temperatures were 170(moving) 190(stopped). The front differential oil was in a ( going bad condition) when i replaced both diffs and transmission oil at about 55k miles, I've added about 33k miles since the last change..going to change the trans oil and front differential oil in about a week so im removing the plates while checking for any leaks from oil seals if there's any.
Sent from my CPH2723 using Tapatalk
