Remote (FOB) start not working 2022 ST
Mr_Gru
WI
My remote start using the FOB would only work hit and miss for the last year. I took it to the dealer under warranty and they said they fixed it, and now it's even worse. The phone app always works, but not the FOB. I told them contact Ford about it and call me when they have a fix. Just wondering if anyone had this problem and how it was fixed.
Of course, they put a new battery in, right?
Jeppo
Davidson County, NC
Does the second fob work?
Mr_Gru
Mr_Gru
WI
Yep. The door locks and hatch work so it has good signal.
Mr_Gru
Mr_Gru
WI
Fixed. Ford said you have to hit the lock button again and then the remote start twice. Even though you already have locked the vehicle. I wonder who the genius at Ford was that thought that was a good idea?
Remote start has worked that way for years. And other brands also.
The owners manual would tell you this.
Mr_Gru
Mr_Gru
WI
I had to take it to the dealer twice for the problem. The first time they reprogrammed the RF module. The second time they called Ford and were told to hit lock again first. You would think they would have known this.
I would look for a new dealer. That is just plain wrong.
sandy, Oregon
For real Tho Lol
Palm Beach, FL
Explorer ST 2022, Excursion 2000
It minimizes the chances of accidentally double clicking the remote start and having the vehicle run unknowingly.
Desert South West
Use the app, had all kind of issues with (fob)remote start depending on how big the truck that was parked next to my St blocking the signal was.
Mr_Gru
Mr_Gru
WI
True. It just takes longer to start using the app. Versus hitting the button on the fob.
Chairborne Ranger
I almost never use remote start but I do like having the option of unlocking the vehicle with the app. Unfortunately, I find Ford Pass is hit or miss with unlocking and only works maybe 60% of the time (and that's with the vehicle sitting in the same spot in my driveway). Good to know about how the fob works though just in case.
Farmers Branch, TX
So wait, the FOB wasn't working because you weren't hitting the lock button before double hitting the start button? The FOB doesn't know if the vehicle is already locked or not, it just knows it doesn't send out a start signal until the proper sequence is followed.
