removing 2nd row seats
ummduh
2021 Explorer Platinum
Like the subject says, we need a little more cargo room in our 21, and was wondering if you can remove the 2nd row seats without pissing off the computers? We would still have the 3rd row seats if for some reason we needed them.
I have not really checked if there are airbags in those seats or not.
Any ideas?
Edit: I see there is already a thread on this, please disregard. Mods can delete if wanted
A lot of people remove their 2nd and 3rd row for weight reduction, haven’t heard it cause any problems for them.
U
ummduh
I found the thread about this, apparently you can't delete your own threads here.
That thread was actually pretty useful.
Massachusetts
2023 ST
I pulled the middle seat out of my bench for more space.
Issue is with the seat belt buckles. When you disconnect them, it causes errors with the seat belt monitoring system so you'll get warnings on the dash. If temporary, don't worry about it. If this is a long term thing, you'll need to disconnect the buckles from the seats and plug them in to the harness.
The buckles are hall effect sensors. Do not jump them with a jumper wire or ECU damage may occur.
Germany
Ford Explorer 2021
Can you pls Picture of this, i would interested how its look like when the middle seat is out of the bench.
mfg
Massachusetts
2023 ST
Here’s a pic.
bought some knock-off floor mats for a 6-seater and it perfectly covered the gap in the middle left
By pulling the middle bench seat. This was supposed to be temporary, but the family likes it this way.
I have the middle seat bench buckle zip-tied under the driver's side seat. I'll likely go grab a buckle from the junkyard and cut/shorten the harness to make a simplified version. Without a buckle plugged in, you get seat belt warnings for the middle. Do not jumper it. The belt minder doesn't work that way I believe it is a hall-effect sensor.
But without the armrests that would be on the typical captains chairs, there is more pass-thru space. Really the main difference between this setup and true captains chairs is you lose the armrests, the seat pattern in the thigh area travels across to the missing seat, and bench seats are manual forward-access, vs the electric button on captains chairs
Nascarbilly
Sacramento, CA
2025 Rapid Red Explorer ST
Welcome Aboard!!
The threads here are extremely useful and, as you noted, go on forever.
U
ummduh
I removed both of the 2nd row seats. Airbag light is on, seatbelt fault as well.
I went to go plug the seatbelts back in, but the plug end is in the seat harness thats.... in the seat. Saw another said to take all that out, so I got started, but quit when i got to the wire that goes all the way up the seatback. Airbag?
Currently just living with the seatbelt fault, i'll have to decide what to do.. I'm not normally dissuaded by cutting wires, but this one gave me pause, lol.
Massachusetts
2023 ST
I removed the seatbelt from my middle seat. Had to snake the wire out of it but it was the only way. You cannot jump the harness connector. Won’t work and may damage ECU.
not aware of there being airbags in the 2nd row. My guess is the wiring you are seeing for the two outer seats is for the power fold function. Bench seats don’t have this but the captains chairs do.
U
ummduh
That has to be it! I just put my seats into storage, way up and way way way back on the shelves too, yay.
Bridgewater, New Jersey
Why do people remove the 2nd row of seats when u can remove the 3rd row and have all the room back there ..
Because without the 3rd row the rear cargo area isn’t perfectly flat.
U
ummduh
Yep, the cargo we carry is all in totes and it fits perfectly where the middle seats used to be.
With the totes up front it's also easier for her to load/unload (it's her stuff and her car). If it got pushed forward into a hole shed have to lean on a long ways and fight to get things out.
I'll try to remember to get a pic, it's kinda impressive how much we get crammed in here
jojorules6398
Kansas
2020 Ford Explorer ST, Rapid Red Tinted Clearcoat
Here’s a pic.
Using an old floormat as a temporary cover to the open spot left in the carpet. This was supposed to be temporary for a summer road trip with the family, but the kids ended up liking this a lot so it's been a few months now. If i keep it like this i'll prob go seek out a peice of carpet I can cut to shape to cover/fit the area better.
anyone looking to trade bucket seats for bench? I have bucket seats and a center cup holder seeing if anyone wants to trade
Massachusetts
2023 ST
If you had asked me when I first got the car I would have been interested, but ever since discovering i could remove the middle seat i've really liked having the versatility. I've switched it up a couple times now depending on needs.
jojorules6398
Kansas
Sorry! Late to the ST gang!
U
ummduh
Thread Starter #17
Fyi, I ended up just unclipping the wiring harness and rerouting it under the front seats, and then proceeded to shove the harness from the middle seats + the female seatbelt in a bubble wrap bag to keep it from rattling.
Getting the harness out of the seats was an absolute nightmare, I hope the car burns down or gets totalled so I don't have to put it back in to sell it lol. Id recommend just trying to buy replacement harnesses.
Massachusetts
2023 ST
That’s what I ended up doing for the middle bench. Hated routing the harness in/out so I ended up buying a new buckle ($35 or so) and digging a harness out of a junkyard vehicle
one of these nights I’ll cut it all up to make a sort of jumper I can just plug into the middle seat plug when I pull the center seat of my bench out. Then it will be 4 bolts and unclip one plug and pull the seat out.
BTW part number for the middle buckle LB5Z-7860045-AA for about $35. Appears to be the same plug connector as all three rear seats and the cheapest buckle (for now)
U
ummduh
Thread Starter #19
I had to plug the modules back in as well, didn't bother to check if it was one or both, I just put them both back in. One of them is for the power fold 3rd row, won't work without the module plugged in. The driver side is the larger module, I assume that's the one for the 3rd row. Just a WAG though
