Rear Sway Bar End Links
Yenko
Milford, CT
I have a 2020 ST and going to buy a rear AFE sway bar. What sway bar end links did anyone end up using? I did send AFE a message on what they would recommend but they have not got back to me yet. Thank you
The stock ones work just fine. Keep them until their worn. Steeda sells an adjustable set if you must.
Y
Yenko
Milford, CT
Thank you Cdubya I probably will buy a new set of factory ones but just getting a idea.
You won’t notice any difference with adjustable sway bar links. I don’t think anyone but @UNBROKEN really runs them and he was probably the first to do it.
Automovil
Chicago
I'm running steeda rear bar but I'm going with steeda links once I get to that !
I’ve also had some break and don’t recommend them because of it.
No reason to whatsoever. You won’t notice a bit of difference.
Automovil
Chicago
Im on air... I had a problem i believe from the camber from it that wheel was rubbing on sway bar link and shaving the head off lol so i have to replace anyway
Charlotte
You don't suggest adjustable end links even if the car is lowered? I hear everywhere that its necessary for optimal sway bar performance and removing the preload inflicted on the car from lowering the vehicle.
That’s all just from a general standpoint on the end links for general vehicles, doesn’t apply to the ST, stock end links are just fine.
Charlotte
Thanks for the input, I’m inclined to take your word for it rather than dumping more money on something that may end up not working out better than oem.
