Mod lists
Out of sheer boredom and a little curiosity because I forgot some things I went through my whole car and made a list of everything I've done to date or have on deck to install.
This is where it's at.
Post up yours...I'm always curious what everyone else is doing.
Interior:
P3 Cars vent gauge
Blendmount
Escort Redline 360C radar detector
Escort M2 dash cam
Newer piano black dash bezel
Smooth dash trim wrapped piano black
Stainless door panel trim
Stainless pedal covers
Stitching Cover steering wheel recovered with red sight line added
Aviator full size rear console with oem ambient lighting
Dash Design DashTex dash mat with interior matching stitching added
Short 2nd row headrests
Ceramic window tint all around including pano roof and windshield
Steering wheel emblem overlay
Red kevlar start button with light modded to change from green to blue
K&N washable cabin filter
Exterior:
Imported Euro headlights
Waido front splitter
Waido side skirts
Waido rear mid-wing
OEM Timberline black grille emblem
ST-Line grille
Shaved rear Explorer panel above license plate
Shaved driver door key hole
Shaved license plate holes in front bumper
Zeus 3D smooth painted hitch cover
Rear OEM belly pan added
Diode Dynamics LED turn and reverse bulbs
Roof rail delete
License plate LED's added then flipped the right side to aim correctly
Houston Speed Freaks rear wiper delete - my prototype design
Tinted rear bumper reflectors
Lamin-X tint on turn/reverse area on tail lights
OCD Plug vinyl covers on A, B and D pillars
UPR piano black lower door inserts
Custom vented hood with Jeep Rubicon vents
Houston Speed Freaks skidplate
Engine:
SPD catted downpipes
Thermal R&D 3" exhaust
Vibrant Ultra Quiet resonators X2
FenFab raw coolant tank
FenFab raw hot side piping
FenFab raw cold side pipe w/Turbosmart BOV
Custom raw aluminum ECM cover
Custom raw aluminum strut tower brace
Whipple intercooler
PPE aluminum trans pan
S&B air intake with custom no-logo lid
SPD 170 degree thermostat
NGK colder spark plugs
Verus Engineering raw billet caps
UPR oil catch can with drain valve
Continental style ethanol sensor
ZFG tuned with 91, 93 and E50 tunes
HP Tuners MPVi2
Redline Tuning pneumatic hood struts
Suspension:
BC Forged EH181 22X10.5 +30
Atturo AZ850 305/35/22
McGard spline drive lug nuts
Rotora brake kit 16" front w/8 pot calipers 15" rear w/4 pot calipers
PIU shocks and struts
Afe front swaybar with adjustable end links
Steeda rear swaybar with adjustable end links
H&R drop springs
FenFab billet vertical links
Steeda adjustable toe links
Dual JXB bushing inserts
Steeda subframe bushing inserts
ID Motorsports prototype rear diff brace
Audio:
Lincoln Aviator screen swap with custom acrylic bottom trim
Screen mount from Dariusz Kedzior
Dash converted to 8" trim and storage tray
Nav TV Zen A2B interface
Helix Ultra DSP
Helix Director controller
Mosconi Pro 5/30 X2 - One amp per side of car
Focal TBM tweeter
Focal 3.5WM midrange
Focal 8WM midbass
Blam FRS3N50 wideband
Acoustic Elegance IB15AU subs X2
X2 Power 96R AGM battery
Stinger wiring, fusing, distribution and optical
RSD Custom Cables silver core RCA's
Custom IB kick panel pods venting into the firewall
Custom a-pillars
Custom dash pods venting into the dash
Custom Baltic Birch IB sub enclosure venting through the spare tire well
Extensive sound treatments including CCF, CLD Armaflex, Tesa tape, butyl rope, lead shot, 3M Thinsulate, etc
I don't think I've seen your ST-Line grill yet. Also, post up some engine bay pics!
Charlotte
I love my thermal 3" but sometimes I wonder how it would be taken down a notch with sound and contemplate if I should have got the 2.5" version. That being said, can you describe the effect the resonators have on your setup? Thanks
East Coast
I agree - seeing the list of mods on other's rides helps with the brainstorming. Here is mine for my 2025 ST:
Installed/Completed:
  • Steeda Strut Tower Brace
  • Steeda ECU Cover in Red
  • Steeda Pro Differential Support System (Rear Differential/Pinion Bushing Kit + Rear Differential Brace)
  • Steeda Adjustable Rear Sway Bar, Medium Setting
  • FENFABrication Rear Billet Ford Badge in Black
  • FENFABrication Front Billet Ford Badge in Black
  • FENFABrication High Flow Air Intake v2
  • FENFABrication Transmission Mount Insert
  • Thermal R&D 3" Catback Exhaust w/ Coated Tips
  • CVFabrication Intercooler in Silver w/ Aluminum Pipe Kit
  • H&R Lowering Springs
  • MRT No Drill Hood Strut Kit
  • AutoStop Eliminator
  • Zeus3D Diffuser Hitch Cover in Textured Black
  • RokBlokz Mud Flaps in Black/Black
  • CravenSpeed 'Platypus' Front License Plate Re-locate
  • Hecotrax ST Pedal Covers
  • The OCDPlug Visor Warning Overlays in Blackout
  • Tinted Front Windows & Front Windshield Banner
  • Tinted Headlight Side Markers, Fog Lights, Side Mirror Lights, Rear 3rd Brake Light, Reverse Lights, Rear Lower Reflectors
  • Steering Wheel Ford Oval Overlay in Red/Black
  • Removed 'Explorer' on Hood and 'Explorer' and 'ST' on Rear Tailgate
Pending Installation:
  • Emblem City Front Grille 'ST' Custom Emblem in Ford Sinister Bronze
  • CVFabrication Catted Downpipe w/ Stainless Steel Gaskets
  • FENFABrication Rear Toe Links in Black
  • FENFABrication Rear Vertical Links in Black
  • Steeda Subframe Bushing Support Kit
  • Velgen 'Classic5 V2' Wheels in Gloss Bronze - 22x10.5 +30
    • Lionhart LH-Five UHP All Season 305/35/ZR22 110W XL Tires
texas
**edited 9/3/25** My installed mods list so far:
P3 Gauge with ethanol sensor
Cobb/Goosetuned 93 and E85 (still in process) tune
FenFab V2 intake
CRP Stage 5 turbos
CVF catted downpipes
Thermal 3" exhaust
CVF hot side pipes
CVF intercooler
CVF cold side pipe w/Turbosmart Gen V RacePort
Nostrum HPFP & stage 3 injectors
NGK colder plugs
RSA Stage 1 Transmission w/PPE trans pan
J & L catch can
AWR diff brace
JXB diff bushing insert
12.9 rear diff bolt
Steeda rear sway bar
Steeda adjustable end links
Steeda vertical link inserts
subframe lockout kit
1-1/4" front & 1-1/2" rear wheel spacers
Superforged Big Brake Kit
Ford hood deflector
HSF full LED kit
Waiting to be installed:
HSF pinion bushings
JXB trans mount
FenFab Rear toe links
You couldn’t pay me to put those pinion bushings in. Seen too many failures and they’re a pain in the ass to swap.
My 2020 mods list:
Interior
Escort MAXCam 360
BlendMount
Custom ST MagSafe Phone Mount
Carbon Fiber Trim Cover
Aluminum Pedal Covers
WeatherTech Floor Liners
CoverCraft Seat-Saver Covers
Center Console Cover
Ceramic Tint
Exterior
Matte Black Racing Stripes
Ceramic Coating
Lamin-X Yellow Fog Light Tint
Lamin-X Smoke Reverse Light Tint
Running Boards
UPR Letter Inserts (Lift Gate)
TVD Letter Inserts (Front Doors)
Optimuz Hitch Cover
AVS Rain Gaurds
HSF LED Kit
Suspension
FenFab Vertical Links
FenFab Toe Links
FenFab Subframe Bushing Inserts
Steeda Lowering Springs
Steeda Rear Sway Bar
Engine
Carbon Fiber PCM Cover
FenFab Black Coolant Tank
UPR Dual Valve Catch Can
S&B CAI
FenFab Raw Hot Side Charge Pipes
CVF Intercooler
FenFab Raw Cold Side Charge Pipe
TurboSmart BOV
NGK Colder Spark Plugs
ZFG 91 DMS Tune
Exhaust
SPD 3" Downpipes
Thermal R&D 3" Exhaust
Audio
NAV-TV ZEN A2B
Alpine HDP-D90 DSP/Amp
Alpine HDA-M80 Mono Amp
Focal Flax Evo 3-Way, Front Doors
Focal Flax Evo 2-Way, Rear Doors
Alpine Halo R-Series 10" Subwoofer
CarLinkIt 5.0 Wireless Car Play Adapter
FL
My 2024 mod list
Interior:
Husky floor mats and cargo liner
Screen protector
Radar mount and wiring
ST pedal covers
Leather center console cover
Center console organizer tray
Phone charger holder
Black steering wheel emblem overlay
Piano black window switch cover plates
Piano black gear shift panel
Stitching Cover steering wheel cover
Ceramic window tint
Covercraft windshield sunscreen
Custom leather key fob cover
Forscan - Bambi, start chimes, double honk on walk away, FENG
Exterior:
Roof rail delete
Removed hood lettering
OEM black Ford emblems
Mud guards
Hitch cover
Hitch locking pin
Silicone license plate frame
LED reverse bulbs
Aluminum jack points
Engine:
S&B air intake
CVF intercooler
CVF hot side piping
CVF cold side piping
FenFab black coolant tank
FenFab black ECU cover with red backing plate
AWE 3" exhaust
ZFG DMS tune
HP Tuners RTD3 device
Mishimoto oil separator
Hood struts
Suspension:
Eibach lowering springs
Velgen VF5 wheels 22x10.5 +30
Lionhart LH-Five 305/35-22 tires
Gorilla black lug nuts
PIU rear swaybar (planned)
Rear diff brace (planned)
FenFab billet vertical links (planned)
arizona
2020 explorer st
I see ppl going colder plugs what's the benefit there?
Generally done with a tune. Most tuners prefer one heat range colder.
arizona
2020 explorer st
Ok thanks ill have to look into that
