Heads up with CVF 2020 Hotside pipe with BOV mount/boss (and customer support)
I just finished an install with a CVF intercooler and pipe upgrade (cold side and hot side) kit on my 2020 ST, with a Turbosmart Dual Port BOV part #TS-0223-1096.
I ran into a problem with the pipe kit.
If you are thinking about using this pipe kit from CVF (Part # CVF 1921AEXPICKIT, this is specific to the 2020 version, that has a BOV flange), before you get stuck in with the install, make sure the BOV you want to use fits on the boss. Mine did not (which I didn't discover until halfway through, which is about the worst time).
The issue is this: the Turbosmart BOV center pillar thing is solid, it does not move up on a spring like the OEM one. When I put the BOV on the flange, it would not sit flush with the mounting surface. (I'll post an image at the bottom of the issue.) This happened because the mounting surface on the flange of the CVF pipe was too tall. It was taller than the stock one by a little over 2mm. And because the center section of the TS is solid, you can't push it down any more. There is physical interference. Even with the o-ring removed from the central pillar, it was nowhere close to sitting flush. So before you start the install,
A note on the stock BPV -- it would sit flush on the CVF pipe kit, but it did so only because the center section is what moves up and down to vent. What this means is that if you installed the OEM BPV, the center section would already be "lifted" by about half, and I have no idea what the OEM electronics would make of this. I don't know if it would sense that the BPV is "stuck open" or something. When mounted on the OEM pipe, the OEM BPV center section was not "lifted" at all.
CVF Support (n)
Support was pretty terrible. I sent them an email on Sat explaining the issue, with details and pictures. They responded Monday around lunch time, which was fine, but told me the issue is with the Turbosmart BOV, and not their pipe -- which was NOT fine. (This is the same BOV they sell on their site along with the kit, by the way.) Their support claimed it was that the o-ring was not large enough on the top -- again, look at the picture I posted here...a larger-oring is supposed to take up that gap? What about the gap between the bolt hole and threads? Obviously, the issue is that the pipe was made incorrectly -- the central pillar mount is just too high for the flange. It's as simple as that. And no set of o-rings is going to correct that, and it's certainly not Turbosmart's fault -- I tested the TS BOV on the OEM pipe. It fit perfect.
So I immediately replied to their email saying how I don't believe they are correct in their assessment of the issue, and specifically why I thought that, and how I should move forward to get this issue corrected. I didn't hear back until the end of the day the following day. So the Explorer say for another full day while I waited for support to get back to me. IMO, this is unacceptable. I contacted them with an issue, and it felt like they assumed the issue was resolved by their single email, despite the fact that I replied within 15 min of receiving their 1st email. Their second email continued with the claim that the o-ring was the problem and has resolved the issue (I can't possibly see how and besides, it doesn't help me right now), and that if I want, I can return the pipes. However, until they revise the pipe, they can't do anything except tell me to run the OEM BPV. So I gave up. It's beyond clear that there was a measurement/jigging issue with the pipe, with the mounting flange and central pillar at an incorrect height to each other. And sitting here with the truck in the garage -- my daily driver -- in pieces, sending the pipes back for a refund wasn't really going to help. What I wanted them to do was send me a new pipe, with the correct pillar to flange height. But they didn't offer it, and because communication was so poor and slow, I said eff it. I couldn't wait anymore, I need my truck back on the road.
My Solution
So what I did was take my CVF hot pipe, the OEM pipe, and the TS BOV to a machine shop. Showed them the issue, which they immediately understood the problem to be what I am describing here, and nothing to do with any o-ring on the TS BOV. They chucked the CVF pipe into one of their machines, and removed material from the central pillar. And guess what. The TS BOV fits now! As does the OEM one, without "lifting." The machine shop was able to turn the job around same day.
TL;DR
At the end of the day, everything is back together and working. No issues. The quality of the CVF parts seems really good. The issue is they jigged the hotside BOV mounting part wrong before welding (or just measured wrong?), so make sure you test fit before tearing your truck down if you are going to do this. Otherwise, no issue with the kit. Minor complaint is that they don't include instructions, so you have to waste some time playing the guessing game with which clamps go where -- it's annoying and it would be super easy for them to provide a legend. But they don't for some reason. You have to watch an HSF (not even affiliated) video to see how to install this kit.
Their website claims "Industry leading customer support" which is frankly just a big fat lie. The experience is definitely sub-par. Waiting a day or two for an initial response is completely understandable, but once support is engaged, I expect responsive replies until the problem is solved; and the problem isn't solved until the customer says "Yup, I'm all good, thanks!" But CVF doesn't do that, nor did they take the time to understand what I am saying. They just threw an answer at me, and one that doesn't make any logical sense. They make you wait that initial response delay each time you respond. It's frustrating, and doubly so when your vehicle is already in pieces, unusable, and is waiting on the conclusion of their support.
So. I would recommend the CVF intercooler and pipe kit with some caveats:
  1. You check the fitment of the BOV before you start taking your vehicle apart.
  2. You don't need support for anything, because based on my experience they will be usesless.
  3. Given that there are other, good kits available for roughly the same price, I would have expected a little more attention to detail here (such as a clamp guide and installation instructions)
If I had to do it over again, I would still go with this kit, I just would have done some stuff in advance before starting in on the install. And then I would pray that I didn't need customer support for anything.
Here's that picture of the mounting problem: on the left, the un-marked picture (TS BOV on the CVF hot side pipe), on the right, same picture but with my markings: RED is the outline of the BOV, GREEN is the CVF central pillar (red and green are physically touching in this picture, without an o-ring between them -- so with an o-ring between them, the gap would be even larger), the PURPLE is the resulting gap, that is supposedly fixed via an o-ring, somewhow. :unsure: The GREEN HATCH section at the top of the pillar is essentially what the machine shop cut away, which allowed the BOV to sit flush to the flange.
Combatvet
I've seen the same response from them, sales is quick, service is like any Ford dealership. I think I'm going to limit my frustration in life and just go with a Steeda intercooler. Thanks for the useful information.
This is well known and actually isn’t an issue. The o-ring seals it and it functions fine. You’re about the 742516394936th person I’ve seen bring it up.
M
Okay, well, a couple things:
  1. Which o-ring are you talking about? There's a small-diameter one on the central "pillar" and a large-diameter one that goes around the flange. Which, specifically, are you referring to?
  2. You are saying it's okay to leave this BOV mounted with a +2mm gap between it and the mounting flange of the hot pipe? That means the bolts that hold it down are pulling against two faces that are not in contact with each other -- this will put A LOT of stress on the bolt holes of the BOV and most likely will bend them and/or crack them. There is no way this can be an acceptable mounting solution. If this is how CVF expects it to be mounted, spacers should have been provided.
  3. As it stands, it absolutely does NOT seal, if I had purchased the Bypass version of the BOV, it would be venting to atmosphere and not through the hose -- while it may not matter to the engine whether it's atmo or recirc, if I intentionally bought a BPV to recirc and it vented to atmo because it doesn't actually mate up properly...that's a problem.
  4. If I am indeed the 742516394936th person to have an issue with this, that sounds like CVF has a problem with their product and needs to address it. ‍♂️
  5. It absolutely is an issue. At a minimum it's poor fitment. How can you say this isn't an issue?
I say it isn’t an issue because everyone else isn’t having any functional issues with the exact same fitment. If you wanna bitch and moan…go for it.
M
I don't understand why you are being a jerk about this. Do you work with CVF or something? Is it run by your brother-in-law? It's a really bad fitment, why are you defending it? I am completely baffled by your response here.
There's clearly an issue, the BOV does not even come close to sitting flush on the on the flange. I'm not bitching and moaning about something insignificant -- it clearly doesn't fit. The machinist I took it to, who's not even a car person, immediately recognized the issue. It's a manufacturing issue FFS, and just because you are an internet forum hero here and are apparently okay with a shit fitment, doesn't automatically make what I am saying here pointless or irrelevant, and I really don't appreciate you trying to brush it -- and me -- under the rug.
Furthermore, this gap affects the functioning of the unit. If you think it doesn't, then you are misunderstanding the actual issue I posted. Now, maybe there's a wide swing of tolerances in the pipes due to poor quality control, and maybe not everyone else's is like the one I received. But that doesn't mean my issue here isn't a thing. It is. There's photo evidence.
Look at the gap in the picture. That is completely unacceptable, I don't care who you are. There is clearly a defect in the dimensions of the product I received. Why are you being like this?
When you try to fit aftermarket parts on top of aftermarket parts, sometimes shit doesn't fit. My TS BOV and CV Fab hot side pipe had a very small gap between the flange, much smaller than yours, and on par with what everyone else has seen with this same combo. My O-Ring was in the hole, so the small gap wasn't a big deal.
Combatvet
Is the easy solution to just buy the FENFAB? Do they have the same issue?
M
A small gap I could totally understand -- the small diameter o-ring that sits on the "pillar" was pretty fat, so I could see how reducing that in thickness just a little would make your situation sit flush.
I want to reinterate here that the gap I'm showing in my picture is WITHOUT the o-ring installed. That's just straight metal to metal. If I had put the o-ring on, the gap would have been even larger.
So I guess in my case, as I sort of expected, my particular pipe was manufactured incorrectly, probably put in the jig wrong before welding. It would have been super if CVF support would have listened to my particular issue and offered to send a replacement. I would have been fine with a small gap, I could have fixed that with a different o-ring.
Also, it's worth pointing out that the Turbosmart fit perfectly on the OEM pipe. So this issue really has nothing to do with Turbosmart, and everything to do with CVF.
Nope…no relation and don’t work for them.
I just get a kick out of people going off over easily rectified issues like it’s the end of the world.
Send the shit back…buy FenFab…”problem” solved.
Now write me another novel please…
M
Having to take the part to a machine shop is not "easily rectified."
I was in the middle of the install, with my truck torn apart, a vehicle I depend on. Sending parts back and waiting for another part to ship and arrive wasn't on the table.
Now your response has moved from "suck it up, stop bitching and moaning" to "buy a different product" -- which is kind of what I was getting at in my OP. Your original reply could have been "yup, they suck, you should check out FenFab." Instead, you act like it was my fault, you are being rude and impatient with me for absolutely no reason other than you can. None of this was my effing fault, yet you act like it was, somehow. I wrote the OP to help others that are on the fence about this product. I can't tell if you are just getting bitter about being an internet hero, or having a bad day, or what, but if this how you choose to behave, stop posting. I never figured you for an asshole. My mistake. So this was great. Thanks for the experience, great place to be.
Why are you this deep in your feelings over a couple hundred dollar part?
Everyone else that’s found this gap has had no issues with their car. CVF has said it’s not gonna hurt anything too. You just didn’t get the response from them you wanted so you come here and do whatever this post is.
If you don’t like the part you bought, yes…return it and buy something else. You have multiple options for hot and cold side piping that’s not for anything other than looks anyway.
M
Are you serious right now? I am now convinced that you do not understand how bad the gap was with the pipe I received. And clearly you, like CVF, are grossly underestimating the issue. I'm not shopping on Temu or Aliexpress. I expected better.
Why are you shitting on me for expecting better? If I had known this was going to be an issue, I would have shopped elsewhere. I didn't know, you dick. So, me trying to be helpful here, I posted what I did so others could see what they might be getting into, so they could know in advance. Your response to that was to be rude, unhelpful, dismissive, disrespectful, and treat me like something here was my fault. For whatever reason, I don't even know.
I don't understand why that's bending you out of shape so badly, and I frankly, at this point, I don't care. I have been patient with you, but I'm done. Please stop posting in this thread. You clearly aren't interested in the issue and would rather just shit on me. Enough. Move along.
Show me one place where I said it’s your fault? You can’t…because I never said that.
Again…if you don’t like the CVF parts, return them and buy something else.
M
Anyway, to sum up for everyone, the kit from CVF is fine other than the BOV mounting issue. If you are buying the kit for later-year STs and/or aren't doing the BOV, then I don't think you'll have anything to worry about. Things fit together just fine.
If you are doing the BOV option, or want to add it to a later-year ST, then definitely to your test fitting in advance, and be prepared to take the pipe to a machine shop or whatever for corrections -- or you can attempt CVF customer support at your own peril.
Lincoln Aviator
Your post will help someone. I had the same problem with my install and figured it out for myself after having the same experience with CVF customer service. In my case, they acted as if they'd never heard of the issue and blamed it on the TS BOV that I bought from CVF as a complete kit. I ended up buying cork gasket material and cutting a gasket to close the gap.
Unsolicited word of advice - In the future, save yourself the trouble by staying on task and not getting distracted by replies that you don't understand or agree with. This is the internet and this is what the internet does.
Enjoy your ride.
Combatvet
CVFAB would really benefit by having someone available to answer their phone. This new era of zero customer service by phone sucks!
M
Thread Starter #19
Same, they basically blamed the BOV.
Enjoy your ride.
Sage advice. I personally strive very hard to make sure I'm as well understood as I could be (given that it's the internet and we are typing), and I try really hard to understand where other people are coming from -- I try to give the benefit of the doubt and initially assume whomever isn't just being a jerk and there's a genuine misunderstanding. It's how I often seem to get baited into these arguments, and after a number of exchanges it finally dawns on me what's happening (nope, it's not a genuine misunderstanding). So next time around, I'll just ignore it. Eventually, I'll learn. (y) :D
M
Thread Starter #20
Oh, I'm okay with the email support -- I've worked with several companies through email and it was a positive, successful interaction that resulted in my issue being resolved. The problem I have with the way CVF does it is that once engaged, they don't stay engaged. The cycle starts all over again once you reply. So it ends up taking weeks just to exchange a couple emails. Eff that noise. It's a joke that they have "Industry leading customer support" on their website. Lol, like not even close to "industry leading."
