Eibachs + PIU struts/shocks
Jessup, MD, USA
I am planning to install Eibach Pro-Kit springs and the PIU front struts and rear shocks soon.
Can someone look at my parts list and confirm I have everything I need? Is there anything else I should replace while I'm in there?
Will I need a spring compressor to get the Eibachs onto the front struts? I've watched a video of HSF and for the replacement, it didn't look like a compressor was required at that step, only for removal.
Southern New Jersey
You most likely not need the strut bearings. I installed my Eibach with 70k on my ST and I now have 102k and still have the OEM strut bearing. But for $20 it won't hurt.
You will need a spring compressor.to take your OEM Springs off, but not to put the Eibach on.
jwuonog
Jessup, MD, USA
I have a little bit of a creak when I stop too quickly and when going over bumps a certain way. I have a feeling it might be the strut bearing, so I want to replace.
OEM springs will stay on the OEM strut, and probably tossed. So is it safe to say I won't need a spring compressor?
Southern New Jersey
If you dont transfer parts off OEM struts you will need - Strut dust cover. Upper and lower spring isolators, bump stop, upper mount, isolator, and bearing. (7,8,5,6,9,10) in Photo
The Eibachs are low enough that you don’t need a spring compressor. You need one for removal though.
I am doing the front struts soon and picked up the bearings just in case. Have 110k miles and 6 years on my ST.
You will still need to salvage the boots and strut mounts from the original struts. As mentioned you’ll need a compressor for that…OR…after the car is on jack stands and the wheels are off, lift one side slightly with a floor jack then take the top nut off the strut. When you lower the floor jack the spring and everything will just slide apart.
jwuonog
Jessup, MD, USA
What is the torque spec for the nut on top of the strut? I just did PIU struts.
I don't have a 21mm pass through socket, I'll need to pick one up in the morning so I can finish the job.
