Rear differential noise on decel
travish325
KY
Currently at 101k miles on my 2020 ST and have had this rear differential noise for a while, probably the last 25k miles at least. It was noticable but just sounded like some road noise before. I recently put on a AWR diff brace and now the noise is MUCH louder as I assume it's transferring the diff noise and vibration through the mount to the chassis.
The noise is only on deceleration off throttle/coasting, nothing while acceleration or under load. It's not a grinding or knocking noise, it just sounds like very excessive road noise like very worn tires (tires are new), no clunking or anything either. I am planning to change the diff fluid this week to see if that helps but I'm assuming it won't fix the issue.... any ideas?
I would think the diff fluid change would help immensely. Maybe it's old or the level is low.
FORZDA3
Gloucester, VA, USA
You’re describing classic worn differential gear noise, likely due to lack of fluid changes, or the original setup was off a bit.
T
travish325
KY
Flushed and changed the diff fluid today and added some Barsleak Gear Repair. The noise on decel is still there, it is a tad less noticable but very obvious still. From reading it seems like it's a pinion bearing issue at this point... Anyone know how hard it is to replace that? I can't even find just the pinion bearing on a parts breakdown for the diff and I really don't want to replace the entire rear diff if not necessary
butt_yodel
Iowa
Dealer diagnosed this as a bad pinion bearing for me today. Started at 3k miles, got very loud by 5k. No leaks. Just bad setup, I think.
Caster
@ 101K Miles you change the ring, the pinion and the pinion bearing. Might as well change the wheel bearings and seals while its all being worked on. If you have never worked on differential ring and pinions and set the backlash before or don't have someone working with you that has, DON'T DO IT YOURSELF. Pay to have it done and done right.
butt_yodel
Iowa
Follow up to this... I had the rear end replaced again. Both replacements started howling from the second they were installed. No solution yet.
Charlotte
what does the dealer say is wrong with them when they replace them?
The Explorer's warranty repairs are bleeding Ford! I'm told local police departments stopped ordering them because they've been so unreliable especially the hybrids.
COBRA90GT
Metro Detroit
^ While Ford has broken the record for the largest number of recalls in a calendar year ( they were just under a 100 and it isn't even close to December ! ), I can definitely tell you that agencies are still ordering PIUs ( not sure about the hybrids - we don't use 'em ! ).
The D.C. area PD's aren't ordering them anymore. They have purchased new Chargers and Durangos instead. My local PD fleet manager told me recently. They're getting Tahoes for K-9.
butt_yodel
Iowa
Small update for future readers. Replaced the OEM carrier bearing with a JXB and it made no difference. Driveline feels tighter though, cool mod (y)
Charlotte
I have a slight what sounds like gear whine from the rear sometimes on decel. Running the steeda brace and JXB insert on my single bolt. I just figured it was diff sounds that are always there but dampened out by the stock bushing and by putting on the upgrades its not getting a bit transferred to the frame.
Only 5K miles on it now , seems to be not getting any worse so will leave it till it does or if it does. I did replace the stock fluid with amsoil 75W110 at around 1000miles.
butt_yodel
Iowa
I’m sure some noise is normal and not cause for concern. For what it’s worth, my ‘22 was dead quiet with the same setup. The noise I’m encountering on the ‘23 cuts through radio and exhaust and lives in your head rent-free. 60 mph is a very unfortunate spot to encounter the issue consistently.
Charlotte
Oh yea, what you are experiencing is pretty F'd.
'22 ST
Did you ever figure it out?
Hull, GA, USA
I have been having the same issue, sounds like a whiring noise on decel. I took off the jxb insert and the awr brace and I can’t hear it anymore. Is this just normal nvh amplified by the brace or something worth having checked. I also changed the fluid and it smelled like rotten eggs at 58k miles. I also wonder if the subframe lockout bushings add to the noise. Any help would be appreciated.
BuckStrickland
West Virginia
People tend to forget that when you tighten things up, you often increase NVH. If you're sensitive to it, and don't have other mods to deaden such sounds (like an exhaust), then you're likely to notice a noise increase, even if it's subtle. I had the JXB on my last explorer, which already had the 4-bolt diff, and noticed added noice on deceleration. I changed my diff fluid just to be safe, and all still appeared well. It's just the nature of the beast. Not sure about diff fluid smelling like rotten eggs... someone couldve done a flush with some cheap fluid that became super sulfurated over time, but a lot of diff fluids use sulfur compounds.
EDWYER
Check for a transmission leak or bad catalytic converter.
